ok geniuses,window tint removal
i hate tint on my windows.plz someone buck up and give me the easiest safest way to get this crap OFF....ty
Re: ok geniuses,window tint removal
You only need two things. TIME and more TIME.
72 Cheyenne Super 80 Silverado Blazer 2wd |
seems like the sientists could creat a wipe on melt off solution,im trying goof off,widex,hate to break out the c-4
![]() Join Date: Aug 2010
You can pull it off carefully trying to get as much off in one peice and then remove the remaining glue residue with ammonia. Please be in a well ventilated area if you go the ammonia route.
#5 | |
70 Chevy SWB Fleet Project. 06 Lancer Evolution MR SE, stupid fast! 03 Ford f-250 crew cab, 6spd, diesel 56 ford f100 project My build thread. http://67-72chevytrucks.com/vboard/s...d.php?t=426739 |
it dont just peel off,scraping and getting results but its gonna take forever this way,cmon some of you truck gurus someone must of found an easy way.....
peal it off in as big of pieces as possible and use glass cleaner that comes in an aresol can we use the brand sprayway its a blue and white can. it seems to break down the glue pretty well. use a razor blade also with the glass cleaner keeping the razor blade wet. carefull not to scratch up the window. its not to bad. Good luck.
the glue in newer tints break down pretty quickly with nothing more than windex with ammonia.
peel off the film ... soak the glue area with windex ... scrap with a NEW razor blade |
more ideas than money
I have used a heat gun with great success. It is still a slow and tedious process, but it helps the glue stay on the tint not on the glass.
Simple green also works well for what glue is left.
![]() 1948 Chevy 3100 5 window 1966 Chevy C30 Dually 1967 Chevy K10 1972 Chevy K20 1972 Chevy C10 1972 Chevy K5 Blazer 1987 Chevy V10 2003 Chevy Suburban |
I've used this method and it worked well. I don't really think there is a "quick and easy" way to remove tint.
-Scott- Last edited by sjarrett71; 10-16-2010 at 11:18 PM. |
wanna buy some "tint free" windows?
![]() you asked for advice! I have used the razor method... plus an hour of my time.
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" Last edited by msgross; 10-16-2010 at 10:14 PM. |
Has more rust than truck...
They make tint-off. Peel off tint, spray and wipe. Should be found anywhere that sells tint....Walmart has it.
I used tint off when I peeled the old stuff off my Dodge before I retinted them.
Worked great.
60 4x4,235,SM420,Rockwell T221,D44/HO33 sold 4/12 67 C-20,292,SM420,HO72 90 Dodge W250 Cummins,NV4500HD,205,D60/D80 93 Dodge W350 Dually Cummins, Getrag, 205,D60/D70 |
My tint guy uses super clean. Don't cut it, use it straight, and use a LOT of it. I have done is several times with excellent success.
You should see him do it. He can do a window in 1 minute. Within 10 minutes, it will be re-tinted. |
#15 |
Go to the Dollar Store and buy Ammonia and a cheap pump spray gun. Easy OFF.
#16 |
Razor blade and paint thinner.
'58 SWB Fleetside...Front & Rear Porterbuilt Dropmember, 6.0 LS /4L60E. Accuair E-level, 20 Billet Specialties (Vintecs) '63 Buick Riviera ... AccuAir E-level, 20" Billet Specialties (Vintecs) http://67-72chevytrucks.com/vboard/s...=528853&page=5 |
#17 |
Let the window sit in the sun and warm up, most of the glue comes off with the tint.
#18 |
A former student of mine who is now a Washington State Patrol Trooper carrys a razor blade and tells the clown with the over tinted windows "you peel it off or I will". That usually gets the job done in record time. There are some around here that I would swear are painted black rather than tinted..
#19 | |
"the other guy"
God Said,"Building A 10 Second Import Is Like Coming Out Of The Closet, In The End Ur Still....."EXPLETIVE" ![]() |
#20 | |
#21 |
Ex-Minitrucker
Always had good luck with any citrus based cleaners. My old job had some called Zone Defense, its an industrial solvent we used to remove all kinds of adhesives just spray it on and wait a few minutes and attack it with a plastic scraper. If you use razor blades you need to bend them a little so they have a slight arch, that way the corners of the blade won't dig in and scratch the glass.
68 C10 LWB 292 4spd 68 C10 LWB 250 3spd Last edited by 68lwb292; 10-17-2010 at 02:52 PM. |
#22 |
one window down,2 to go and thank you guys for all the great responces i will get this done!
#23 |
after peeling tint use rubing alcohol and razor blade what i have used in the past worked perty good, good luck
#24 |
Redefining LowBudget
brake cleaner
#25 |
![]() Join Date: Jan 2008
I used to work in a glass shop doing auto glass, we always peeled it off, then wiped the glue off using Denatured alcohol. It worked like a charm!
