My crewcab 4x4 cummins project
well i bought another crew cab..you may remember the bagged crew cab dually i was building with the cummins...well i sold the truck and decided to go up instead of down....its an 1985 GMC K3500 welfare model...there isnt even an interior light in it...It has a running 350/4sp manual which is perfect for my cummins swap... the only problem that in a little sketchy on is the front drip rails here missing for how long i dont know.
Alot of the steel on the truck needs to be replaced but thats fine im not shooting for nut and bolt resto on this on its just onna look cool and be functional. my plans are to go threw all the steel...cab corners, rockers, new doors, short box conversion, install a 8 inch lift and 37" tires, fab bumpers which i have a local guy in town doing for me that used to build alot of them...stick the 12V in the truck with the 5 speed, and run a devorce transfer case ... heres some pics from my phone the truck looks alot better in the pictures than it does in real life....its gonna be some work but it will be worth it in the end....i plan on doing every bit of work to this truck on my own with the exception of the bumpers cause it was a little trade deal we had. |
Re: My crewcab 4x4 cummins project
Looks like a great specimine to start with! Love the diesel plan!
Project #1 "Pops"--1980 Chevrolet Scottsdale C10 3rd Generation in the same original owner family. GOAL: Restore to "almost" original. View Project Pops HERE Project #2 "Cletus"--1986 Chevy K20 4.10 Gear Ratio GOAL: Restore into a heavy duty work/plow rig View Project Cletus HERE - SOLD DD--2008 Duramax CCSB |
can't wait for build pics! gonna be an awesome truck, good luck!
85 GMC SWB: Fuel Injected 454, TH400, soon to be laying frame on 22s 96 Trans-Am: Full bolt-ons, Weld Rodlite skinnies and fatties 95 GMC Yukon 4x4: 2door all stock with the exception of glasspacks and duals |
« Reply #5 on: Today at 10:49:07 PM » Quote Modify
-------------------------------------------------------------------------------- well ive been slacking so quick update....i aquired another crew cab due to rust on the other cab that i didnt want to deal with.... might have been fine but i dont need it to rust out in a few years after its all done...i want to drive this unit full time....so i got a 2wd crew cab from a guy ive done some work for in town told me i can have the truck if i pull the engine....so the last 2 days myself and a few buddies tore out drivelines and front ends, and cabs i put the 80 cab on my 4x4 frame whish i kind of like the 73-80 front end they look more " heavy duty". Also ordered a crossmember from avalanch engineering, and searching for a 8 inch lift that om hoping to have for next weekend.... |
Nice...planning on doing more a less the same thing with my cab and chassis. Will be watching this one like a hawk.
Why the new crossmember? Fitment issues with the cummins? |
6>8 Plugless........
![]() Join Date: Sep 2007
Yes, the cummins is really tall and the stock crossmember has to removed and lowered to get the engine down far enough to be able for a bell housing to come up without hitting the floor on the cab.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
Woo hooo got a lift kit pieced together ships out tomorrow.... Hopefully a weekend project getting the cross member in and the lift in... Lift is from Bds there making an 8" for my truck none of that soft ride springs.... Going with an additional leaf in the front spring pack and getting an extra inch block for the rear just in case it sits nose high. ..... Yay excited
Posted via Mobile Device Last edited by Pullin81; 10-26-2010 at 08:28 PM. |
So why not just do a body lift if you are building a lifted truck? Just curious, not critisizing....just want to know before I jump into doing mine.
![]() who is the rider in the green cab? Sounds like a cool project....count me in! ![]()
Arrived on a Pale Horse
Subscribed! Similar work in the near future here.
Jason 87 V30 350TBI/400 White w/Boss V-plow 89 R3500 CC SRW |
Member of the longbed union.
cool truck.
Paul 88 GMC Crew Cab dually, 454/T400 64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it! 92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759 |
Very cool!
I have been looking into doing this myself on my 87 crew, may be a while though.
Sounds like you already have a good grasp on what you need to do, but just in case I found a ton of info here http://www.4btswaps.com/forum/index.php on Cummins swaps. Looks good so far, I will watching to see how she comes out. |
***On Edit, Pullin81, if you would like this deleted just let me know. I don't want to fill your thread with pics of other trucks than your own build. ***
A body lift a lone won't be enough to get the engine where it needs to be. You can do a body lift and set your cross member according. Another critical thing I should mention is axle to oil pan clearance. On a stock suspension chevy like these, the cummins oil pan is real close and can hit unless you lift the truck or alter the oil pan. For instance here are the pics of my brother's 84 K20 I started a few years ago. It has a 6" lift with 36's. This truck does have a 3" body lift. I had to put it on to clear the ford ZF5 speed bell housing and the engine adaptor because I didn't want to cut the freshly painted firewall. Engine sat in. ![]() New cross member before paint. ![]() Side view of engine in truck. ![]()
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. Last edited by Dieselwrencher; 10-26-2010 at 10:50 PM. |
#15 |
also that front sump oil pan probably makes for clearance issues to eh?
#16 |
It does. But it isn't bad at all on his truck. I got that engine cheap and gave it to him. I might change it later, but I doubt it. It has plenty of clearance and those hold more oil which will help keep oil temps down and oil longivity will stay up too.
#17 |
well i did a little work on the truck today...got the hydroboosts systems swapped off the cabs , and the crossmember in from avalanch engineering.....lift kit is supposed to be here on wednesday and hopefuly tackle that this up n coming weekend.
#18 | |
Your build is looking good. Last edited by pvkj454; 11-08-2010 at 10:38 PM. |
#19 | |
#20 |
well i picked up some rolling stock today...new eagle wheels and a set of used 37x13.5x17 procomp tires when it comes time to get new tires im going to go with 38s
#21 |
I'll subscribe to anything Cummins!
1973 k20 Suburban 350 1974 Custom stepside c-10 250 1975 Chevy stepside 454 1986 K30 Crewcab SRW 350 R.I.P- glimmertwin01- board member and good friend, you will be missed |
#22 |
So, with the clearance issues at hand with the crossmember and the front differential, could you not just put motor mounts in place, and relocate the crossmember somewhere further back with some DOM tubing or something that does not need so much property?
Just curious, not critisising. Just want all the ins and outs before I start mine is all. |
#23 | |
#24 |
The one Auto World sells is much nicer, but is a little more costly. Once I get a 73 up 4x4 truck to use for mock up, I'm going to start building some.
#25 |
well worked my off the last three days after work... got the bds 8" lift in and the cummins set into place
