10-19-2010, 06:25 PM | #1 |
1 Ton Dually Split Rims
Do these have any value at all?
I have a full set of 6ea. off a 1972 chevrolet and was thinking of putting them on craigslist at $10 ea. Is that too much ... not enough ... or what? Thanks ... Paul |
10-19-2010, 07:40 PM | #2 |
Rottenwood Garage Member
Re: 1 Ton Dually Split Rims
We just got through this weekend fighting with mounting up new tires on ours. We now have great appreciation for the guys who do it for a living! It took three of us at one point to get the old original tire off the rim. We looked like the expression with the monkeys and a football.
But back to your question.....there is always some purist or person on a budget that could use them so put them on and see what happens......NEVER again for me....I have owned 3 C-30's with these things. What do you have? What did they come off of?
2004 Chevrolet Suburban C1500 2001 Chevrolet 2500HD Crew 6.0 1999 Harley Davidson Electra Glide 1972 Chevrolet C-20 Custom Camper "Dump Truck" 1972 Chevrolet C-20 Suburban "Big Green" 1969 Chevrolet C-50 Wedge Hauler "Leonidis" 1966 C-10 2x4 short fleet 327 4 speed "Race Truck" 1952 Plymouth Cranbrook "Rican" (my grandfathers) 1931 Ford Model A Coupe "Black Beauty" 1930 Ford Model A truck "Club Cab" 4x4 Rottenwood Garage and Speed Shop.....where everything must be racy! It's not just a hobby..It's a LIFESTYLE!!! Thanks for nothing Barrett-Jackson You cant fix stupid or teach accountability! Time wasters, looky Lous and tire kickers are everywhere! |
10-19-2010, 07:50 PM | #3 |
72freak, Thanks!
Its a 72 C/30 Flatbed It's already been upgraded w/ the newer / safer rims ... I was just checking to see what the old ones were worth before I posted them on C/L |
10-19-2010, 09:01 PM | #4 |
Post a picture of that jewel.
10-20-2010, 10:48 AM | #5 |
Here's the "jewel", We got it for a farm truck.
10-20-2010, 10:52 AM | #6 |
10-21-2010, 06:00 PM | #7 | |
The lug nuts for the hub centric rims are flat not tapered. And my wheel studs are the small 1/2" variety. So that's why I'm wondering which rims would be good replacements. Thanks. |
10-21-2010, 07:23 PM | #8 |
[QUOTE=Todd C;4253002]I am wondering what rims you put on the truck to replace the split rims. QUOTE]
Todd, The rear end has been replaced w/ a later model 14 bolt Gm (I think). And the previous owner must have drilled out the org. front rotors and retro-fitted w/ 9/16's lugs. |
11-23-2011, 07:04 PM | #9 | |
thanks
1972 C20 BB402 1987 3/4 2WD 350/SM465 (soon to be shortbed) 1975 1/2 4wd shortbed 350/SM465/NP205 Big "O" |
10-20-2010, 10:59 AM | #10 |
is it worth $40 to possibly expose yourself to the liability of someone killing themselves when they install rim wrong and blow the ring off? i scrapped my 3/4 ton splits
1969 GMC 3/4 ton, 307, 4-speed NP435GL, DANA 60, 4.10, HD rear leafs, manual everything, leaking oil and water. Now rocking 383, NV4500, power steering, power brakes. Finally undergoing restoration. |
10-20-2010, 11:04 AM | #11 |
10-20-2010, 11:45 AM | #12 |
Depends on where you go......I scrapped 2 the other day with tires on them with a 3300 pound load of scrap..
2004 Chevrolet Suburban C1500 2001 Chevrolet 2500HD Crew 6.0 1999 Harley Davidson Electra Glide 1972 Chevrolet C-20 Custom Camper "Dump Truck" 1972 Chevrolet C-20 Suburban "Big Green" 1969 Chevrolet C-50 Wedge Hauler "Leonidis" 1966 C-10 2x4 short fleet 327 4 speed "Race Truck" 1952 Plymouth Cranbrook "Rican" (my grandfathers) 1931 Ford Model A Coupe "Black Beauty" 1930 Ford Model A truck "Club Cab" 4x4 Rottenwood Garage and Speed Shop.....where everything must be racy! It's not just a hobby..It's a LIFESTYLE!!! Thanks for nothing Barrett-Jackson You cant fix stupid or teach accountability! Time wasters, looky Lous and tire kickers are everywhere! Last edited by 72freak; 10-20-2010 at 11:46 AM. |
10-20-2010, 01:23 PM | #13 |
i took sawz-all to tires, rims to scrap
10-20-2010, 01:29 PM | #14 |
Nice truck! I like it!
http://67-72chevytrucks.com/vboard/s...d.php?t=355153 |
10-20-2010, 02:04 PM | #15 |
What's the deal with split rims? What makes them dangerous?
'68 C10 LWB 6.2NA/NP833 3.73's |
10-20-2010, 02:13 PM | #16 |
from another forum:
"Split rims have a removable ring (that is split) on one side of the rim, usually the outside. This makes removing the tire off of the rim easy, no tire machine is needed. However, if the person installing the rim ring back onto the rim does not know what they are doing, they could be killed, if the ring flys off during inflation of the newly installed tire. The safest way is to inflate the tire in a cage designed for that purpose. My 1973 Chevy pickup had split rims. I used to fix my own flats, and wrapped a log chain around the tire and rim several times before inflating the tire. I used to hammer the perimeter of the ring the during the inflation process, to make sure it was seated. "
10-20-2010, 08:52 PM | #17 |
GMCBubba has it exactly right. The only thing that makes these rims dangerous is the person who is mounting tires on them.
There is no question that accidents, including fatal ones, did occur due to user ignorance or negligence. However, given that split rims were the norm for at least 40 years, I feel they have a rep they don't deserve. If they were truly that dangerous, they would have been abandoned much earlier. The best reason for not using them today is that there is a growing number of shops which refuse to work on them (because the old guys who know how are dying off). If you can mount the tires yourself and know how to take proper precautions (like a barrier between you and the tire when inflating) these rims will work as well for you as they did for millions of owners in the past. Ray |
10-20-2010, 09:23 PM | #18 |
yep...I have monted my share of them in the back yard garage.....just dont air them up with the ring facing out or at you and dont stand in front of them when putting them on the truck. They also can be a llittle hazardous to motorcycles rididng next to you when you hit a large bump.
10-21-2010, 12:26 AM | #19 |
Too many projects
Some heavy equipment, especially in the military still use split rims. They can't be that dangerous when a $200,000 loader comes with them for our use.
Last deployment I could build a grader tire in about 30 minutes using improvised tools and a grader blade over the tire during inflation. These things are dangerous while building, but once they're on they're on. Just use your head building them. I'm even considering putting a set of 3/4 ton split rims on my burb's winter tires so I can build my own if I feel like it.
Andrew 84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck" |
10-21-2010, 07:24 PM | #20 |
Old Duffer
I gave my two-piece wheels to the local scrap yard. In my state it's mandatory that any two-piece wheel be serviced in a cage. My wheels weren't split-rims in the strictest sense, but had the main wheel body with a closed ring with notches made into them that fit over the retainer part of the wheel. Kinda hard to explain, but the ring was continuous, it didn't have a "cut" across it like the 18 wheelers do.
Agreed, these are hub centered wheels, I ended up getting another set of solid wheels, installed 9/16 lugs, and a set of lug nuts with captured washers. Bpawb, good looking truck, what are your plans for it?
'68 Short C20 Flatbed Dually w/ 292 4bbl, Langdon cast headers, and WC T5 trans. '81 G10 Shorty Van "Good judgement comes from experience, and a lot of that comes from bad judgement." Will Rogers "Under promise, then over achieve." |
10-21-2010, 07:53 PM | #21 |
10-22-2010, 08:09 AM | #22 |
What a classy way to run to town for supplies.Custom Deluxe to boot!
