Kvn1011
Can you please add anything that i may have left out for a carb set up, thanks!!
assuming the engine will be stock for now, what else would I need? Posted via Mobile Device |
Truck and auto performance nut
Re: msd box,intake manifold,carb LQ4, motor mounts, th350 adapter
fuel pump and regulator, exhaust manifolds/headers, intermediate pipe or complete exhaust, accessory drive and components, any hardware, etc. (cause there's always something
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
Kvn1011
ok, perfect i plan on taking the plunge pretty soon!!
thanks! |
Kvn1011
waiting on delivery now 2005 denali 88,000 miles all accesories etc
now i want to go carb'd msd 6010 and victor jr 29085, are these the correct part numbers?? i plan on ordering them today thanks kevin also at http://teamc.com/ i found the msd box @267.00 and the victor jr ((assuming i have correct p/n priced @329.00 ) just making sure i have the right parts to get started, then as money allows ill get the other pieces thanks kevin |
#5 | |
I have the crank spacers if you need them for $45 shipped
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap Last edited by Shon; 11-03-2010 at 10:13 AM. |
I will ship the 29085 for $350, teamc wants $353.xx
In stock and ready to go. the MSD unit is back ordered from MSD and should be ready 11/15.
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap |
Kvn1011
Kvn1011
ok here is a th350 via google
![]() and my LQ4 from the looks of this would i just need to elongate the holes circled in red on the flexplate of the Lq4?? ![]() |
You have to buy a spacer. A TH350 converter pilot (black circle) is not long enough. DO NOT just redrill the flexplate....If you do the converter will be "off center" in relation to the crankshaft, This will ruin the converter & the front pump in your transmission.
Kvn1011
ok, That makes perfectly good sense!!! seeing it and reading it to me makes a world of a difference!!
thanks clinebarger!! i was researching on my own and found this, it will help those who may need both spacer and fly wheel. it comes with flywheel, spacer and bolts at $50 all new from GM. http://www.gmpartsdirect.com/results...umber=12621399 ![]() With this GM part number 12621399 you get everything. |
I bought an everything kit from Pace for my 200-4r. The flexplate that was supposed to fit didn't match my torque converter or a t350 from what I could determine. The converter pilot fit so well though into the machined spacer into the flexplate, nice and tight. Considering I had bought a spacer and later realized I would still have to get a new flex plate...so I just bought this Pace kit. When it fit nicely but the holes were a bit off.....I drilled it. This made the mounting holes elongated but due to the pilot fit I felt since it was centered so well, that even though I wasn't using a drill press...the end result with a small equal amount of metal removed would be a good working/centered/balanced fit.
In this circumstance.........is my flexplate now junk? I bolted it to the converter using ARP bolts. No nuts were required for my flexplate as it had like captured nuts welded to the tabs. I was considerate to balance in my mod....but couldn't gaurantee its as good as a "proper" flexplate would be.
#12 | ||
#13 | |
Kvn1011
http://www.pirate4x4.com/forum/showt...php?p=10063967 Here is the google results link....... http://www.google.com/search?q=12621...ndroid-verizon And a seller with same part number with higher pricing and description http://www.crateenginedepot.com/stor...P2399C120.aspx And one of many forums that talk about the application http://forums.corral.net/forums/show....php?p=9410073 Posted via Mobile Device Posted via Mobile Device |
thanks! I'll be hitting it with some HP and don't want to have to walk home from the race track.
#15 |
True Addiction
Hey Guys, I just bought an LS376 / 480. I believe this is the piece I need in order to hook up to my 4L80E. Any confirmation or recommendation would be greatly appreciated. Don't mean to hijack the thread.
Thanks, nice work kvn Posted via Mobile Device
RCC |
