Old 10-20-2010, 02:09 PM   #1
Rodk65
Rodk65's Avatar
Here I go again. HELP
I recently purchased a 71 C20 camper special that Sharpie had for sale. I have intentions of using this truck as my daily driver/tow vehicle and I keep telling myself it is a quick fixer upper and drive. I find myself looking for information that is going to get me in trouble. It is a 350/350 with leaf spring rear with 4:10’s.
I am considering a gear change to make it more highway speed friendly. Anyone know what it available?
The truck has upper and lower trim (see picture), but the bed is not the original and never had trim. Is this trim still available and can it be installed on a bed that never had it? Maybe I should remove all of it.
On other trucks some of the lower trim is painted black and some is wood grain. Why is there a difference?
I will be converting to HEI to make it more reliable. I have heard a lot of people talk about a certain HEI dizzy that was reliable and affordable. I believe it was on EBay but I can’t remember the name. Or I could use the one pictured below. I don’t have any history for it and I would need to replace cap and rotor.
I had thought of changing everything over to ½ ton with 5 lug but that seemed extreme and expensive so I purchased a ½ ton SWB coil spring 5 lug frame that I might blast, paint and change everything over to. It never hurts to have an extra frame sitting around just in case I don’t get over this sickness and end up building another truck.
I am leaving Friday to go and pick up the truck. If anyone from my neck of the woods has purchased something from Sharpie that they need transported back towards Wisconsin I would gladly bring it back if I have the room. I live in Holmen, WI 4 miles from the Minnesota border and just north of interstate 90.
Name:  71 cab 004.jpg
Size:  40.1 KBName:  IMG_20101013_184025.jpg
ROD
1969 K10 4x4 Short Fleet. Tuned Port Injection 350/700R4, Cruise, tilt and factory A/C.
1971 C20 Camper Special. 350/350. SOLD
2002 Chevy Tahoe LT
Rodk65 is offline   Reply With Quote
Old 10-20-2010, 02:16 PM   #2
heavy71chevy
heavy71chevy's Avatar
Re: Here I go again. HELP
All I can anwser for possitive is about the trim...it is still available from lmc and others and it can be mounted to your no trim bed...If memory serves it was just a matter of drilling holes for the clips
"Dixie Destroyer"
71 C10 LWB Fleet
Future Blown Prostreet Monster
heavy71chevy is offline   Reply With Quote
Old 10-20-2010, 02:58 PM   #3
Rodk65
Rodk65's Avatar
I will check out there catalog. Thanks
ROD
2002 Chevy Tahoe LT
Old 10-20-2010, 09:14 PM   #4
Rodk65
Rodk65's Avatar
What is the quality of the trim from LMC?
ROD
2002 Chevy Tahoe LT
Old 10-21-2010, 04:20 AM   #5
raycow
It depends on what axle you have in there now. If you have an H052 (perfectly round cover) 4.10 is the tallest you can go. If a Dana 60 (irregular shape cover) you can get at least down to 3.54. However, if you have to pay someone to set up the new gears, it will usually cost less to do a complete rear end swap than to replace the gears in the Dana. In that case, you might want to look for a corporate 14 bolt. These are more plentiful than the Dana and are available with gears down to 3.21. If you have the H052, a rear end swap is your only way to get better gears.
Another possibility would be to replace your present transmission with an overdrive type like a 200-4R, 700-R4 or 4L80E. This might be preferable to a rear axle swap if you use the truck for serious towing, especially with a TH350. It will be more $ though.
Ray
raycow is offline   Reply With Quote
Old 10-21-2010, 10:02 AM   #6
Rodk65
Rodk65's Avatar
Ray
Thanks Ray. I will look into the Corp 14 bolt swap to see what is available. I thought they were wider then the Dana 60 that I have. I might see if I can find a Dana 60 3.54 or a I will look for a overdrive trans.
ROD
2002 Chevy Tahoe LT
Old 10-21-2010, 08:42 AM   #7
VA72C10
VA72C10
VA72C10's Avatar
Trim is available aftermarket. LMC will be higher priced than most. Try looking for some nice originals too.
Different trim levels (custom, cheyenne, cheyenne super...
Skip White HEI is the one you're thinking of. Many have run with no problem but some have had issues with theirs.
Sonds like a good plan!
Attachment 646152
Attachment 646153Attachment 646154
Answered above in red. Looks like a really solid starting point. Enjoy the build!
Old 10-21-2010, 10:45 AM   #8
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Here's the link to the HEI on E-Bay. This is the store so just surf through it and you'll find several distributors or do a search for v8 distributors. I posted the web link cause they sell tons of stuff for chevy and gm.
http://stores.ebay.com/whiteperformance1
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 10-21-2010, 11:23 AM   #9
Rodk65
Rodk65's Avatar
Thank you for the link. That is the one that I had read about. A new Skip White is about the same price as rebuilding the ACCEL that I have and I know nothing about it.
ROD
2002 Chevy Tahoe LT
Old 10-29-2010, 01:28 AM   #10
Rodk65
Rodk65's Avatar
Well, we made it home. I highly suggest everyone take a road trip to Wyoming to visit Sharpie. Beautiful part of the country and Dennis and Tara are great hosts. Looks like I will need a driver side rocker and a patch for the driver side floor board. The truck runs and shifts great and I am hoping that the HEI conversion doesn't affect how great it runs. I have to find out some info on this Carter AFB carburetor. Will post more pictures as thing progress.
Size:  34.4 KB Name:  IMG_20101026_201654.jpg
ROD
2002 Chevy Tahoe LT
