Loose Steering Column - repair or just buy another?
The steering column in our 69 C10 is loose... has a lot of play in it and you can grab the steering wheel and move it quite a bit - up and down, side to side. The outside of the column seems stable, so I'm assuming it is the internals... looks like there is a lot of bearings in there. Is it worth buying the parts from LMC to rebuilt it or should we just buy a used one?
69 Chevy C10 88 Sierra 02 2500 Suburban And too many S10s to list! |
Re: Loose Steering Column - repair or just buy another?
try taking steering wheel off and tightening nut on shaft to try and remove slop// also check bottom of shaft where it comes out coulmn there is supposed to b spring and washer there(good pic in lmc catalogue)
71c-10 350/2004r/4:11 lowered3/4 longbed/dead by hurricane MEANING OF DEATH::::: SOMEBODY ELSE GETS YOUR STUFF DONT BELIEVE EVERYTHING YOU THINK TAKE MY ADVISE;I DON'T USE IT ANYWAY Last edited by cdowns; 10-21-2010 at 04:30 PM. |
needs more $$$
Good advise. Mine had a lot of slop in it too. I messed with the bolts next to the shaft in the engine bay which took care of the back and forth. The side to side looks to be a worn bearing that you can buy from the catalogs...
1970 2wd Blazer |
Its a Truck Thing......
The bearing replacement will cure alot of the slop, if its not a tilt column its pretty easy to do yourself. There are only two bearings, top & bottom one.
Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 71 C20 Longhorn/Ole Yellor 69 C30 Former Motor Home, Flat Bed time |
Just did this last winter. Piece of cake. Striped it down cleaned it up painted works like a champ. Down on the bottom end were the spring rides it had worn the shaft down. Welded her up good as new. Bought the parts from LMC
Thanks guys. Looks like LMC will be getting more of our money. I like the idea of cleaning it up and painting it too... especially since the truck is a different color now.
