10-21-2010, 10:51 PM | #1 |
Flywheel Cover..
I've got my 70 with a 5.7 350 and the Flywheel cover isn't fitting. Are there different sizes?
10-21-2010, 11:20 PM | #2 |
Re: Flywheel Cover..
If you have a TH350 'K' case, they had an aluminum pan. Could be your problem...got pics?
TH 350 had 4 bolts, "K" case has 6
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 10-21-2010 at 11:22 PM. |
10-21-2010, 11:50 PM | #3 |
haha yea i had that problem too on my 72 (th350, not a k case)...did you get it from LMC? cause all of the holes were a good 1/4-1/2 inch off. turns out it was the part of the cover that covers the starter, it was running up against it. i had to shear it with some tin snips to make it fit.
1972 k/5 Blazer 350V8/TH350/NP205 "The Ox" |
Tags |
cover, flywheel, flywheel cover |
