Old 10-23-2010, 10:41 AM   #1
Irishpilot
GM dress up kit/importance of breathers!!
Hey all,
For those of you wondering about the GM performance engine dress up kits, here is the flat black one I installed on my 406. The aluminum valve covers are really nice looking when you don't drive the truck every day. They are just too much work to keep nice. Here are before/after pics.
Also, for those of you who are burning oil through the PCV valve (like I was for the last few thousand miles). If you don't have baffles on your valve covers...get them!! That solved my problem immediately. They are really important to keep from burning oil, while relieving crank pressure.
Anyways, let me know what you think, good or bad about the flat black look.
Alum:
Flat Black:
1971 C-10, 406ci, restoration begun!
406ci sb; zero decked, bored .030, edelbrock aluminum e-tec heads, edelbrock performer RPM intake, comp 268 cam, comp 1.6 pro-magnum roller rockers, MSD street fire HEI, MSD 8.5mm wires, Holley Street demon 770, Hedman LT headers. 10.6:1 compression, Air Ride Tech bags on all 4-corners.
Irishpilot is offline   Reply With Quote
Old 10-23-2010, 10:49 AM   #2
Slick67
Sofa King Crazy!!
Slick67's Avatar
Re: GM dress up kit/importance of breathers!!
Yep, huge difference!! It looks really good. Try using black touch-up paint with the brush to paint some bolt heads, makes it look detailed! Keep up the good work!
You found the Tater.
My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650
My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650
67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS.
1972 2wd Blazer "Porterbuilt and Sloshed"
Slick67 is offline   Reply With Quote
Old 10-23-2010, 11:01 AM   #3
Cisco714
It comes to preference, And I must say the after pics look really good with the Flat black. Thanks for sharing.
Cisco714 is offline   Reply With Quote
Old 10-23-2010, 11:28 AM   #4
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
In an open or closed crankcase system, it is extremely important that there be a path for air. That air enables the engine to breathe...internally. Remember, those pistons moving up and down within the cylinder bores are compressing air on the topside (for combustion) and moving air within the crankcase (because the pistons are moving up and down). So, the air that is moved and creates blowby gasses, has to go somewhere. Until '63, most engines had a road draft tube, that vented those gasses to the outside....usually off of the backside of the engine and onto the ground beneath the vehicle. When PCV valves became mandatory, they enabled those gasses to be introduced into the combustion process. About '68 (or so) the oil fill on the intake moved to the valve cover and was a cap. The air for the crankcase became sourced from the funky little filter in the side of the air cleaner housing. That made for a closed crankcase ventilation system and it became more important for that air path to be maintained.
So, you're right to make sure you have the proper venting equipment.
Member Nr. 2770
Old 10-23-2010, 12:27 PM   #5
Irishpilot
LoRay, those are good words on the PCV system. I know I went without the breathers because my valve covers wouldn't clear the 1.6RRs. That was a mistake. The tall valve covers clear no problem with the breathers attached.
Old 10-23-2010, 12:56 PM   #6
big_al_71
big_al_71's Avatar
Love the black crinkle gm performance dress up kit. I instaed one in my 65 El Camino's 327.....
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 10-23-2010, 02:31 PM   #7
stich626
like it..
stich626 is offline   Reply With Quote
Old 10-23-2010, 02:50 PM   #8
Irishpilot
Big Al...looks just as good on that 327!
Old 10-23-2010, 04:31 PM   #9
sleepertruck72
sleepertruck72's Avatar
I personally like the before pic, but I think the satin black finish looks nice on your truck. Did you use adapters for the valve covers ? I have chrome GM center bolt valve covers on my truck and the breather always keeps the valve cover dirty to the point where the chrome is peeling... so I know what you mean about dirty valve covers
72 C20 Longbed
05 1500 Z71
sleepertruck72 is offline   Reply With Quote
Old 10-23-2010, 05:18 PM   #10
Ed 72 Sierra Grande
Ed 72 Sierra Grande's Avatar
Originally Posted by Irishpilot View Post
Hey all,
Alum:
Flat Black:
Nice Dress Up!!
Now tell us about your AC / I noticed you did some upgrading there.
Any parts or CO info would be helpful.
Ed F
1972 Sierra Grande
White Top Medium Olive
402 bb / Camper
Stock, Loaded, Straight & Aged Nicely, No Tilt
Original Resto would be nice $
Ed 72 Sierra Grande is offline   Reply With Quote
Old 10-23-2010, 09:42 PM   #11
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
Originally Posted by Ed 72 Sierra Grande View Post
Nice Dress Up!!
I was gonna ask the same thing. Its the Oldair kit I put in mine, I just haven't charged it yet. How do you like it?
And I really like the look of that flat black. Better than the chrome.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
Old 10-23-2010, 10:58 PM   #12
Irishpilot
I don't have adapters for the fasteners because the heads have both the center and outer mounts. They are the edelbrock alum etec heads.
You guys are correct, that is an Old Air AC that I recently installed. It was an awesome mod! I just moved to Las Vegas and it is an absolute must for a daily driver. The install took about three days to finish and get charged. But it works as advertised and is a clean install. I kept my original controls, and it works great.
The kit is complete and the lines are already at length. You will have to cut a hole in your firewall for the drain. Since I had things apart, I upgraded the alternator to a 12SI unit.
