Old 10-24-2010, 11:07 PM   #1
mr and my 409
death wobble
i have a 67 2wd i just replaced all the front suspension parts and got it close to alignment and the steering wheel has play in it,
could the steering box have anything to do with the death wobble?
mr and my 409 is offline   Reply With Quote
Old 10-25-2010, 05:52 AM   #2
stich626
Re: death wobble
yes it could,,
you did tight'n down all your new parts?
never hurts to double check
with the stear wheel unlocked, grab the shaft going into the box, (vice grips work here) and see how much "play " you have before the pitman arm starts to move,
you might see the rag joint is your issue(the rubber joint the your box and shaft bolt to)
that and a sloppy box can make for a odd feeling down the road..
good luck..
have to look, (it's 5am now) but some boxes have nut and screw on the top (like a holley float set up)
to adj the slop out of the box, don't know it these do(readly haven't looked at mine)
stich626 is offline   Reply With Quote
Old 10-25-2010, 09:31 AM   #3
Lee H
Lee H's Avatar
Re: death wobble
Under what conditions are you getting the death wobble? What size truck and tires/wheels do you have? Close on alignment is not good enough and could be far enough out that it contributes to the death wobble. An alignment shop will check out all the components before they align it and, at least the reputable ones, will not align it if there are warn out parts.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 10-25-2010, 12:52 PM   #4
mr and my 409
Re: death wobble
i have 15x8 wheels and a 235 60 r15 tire nothing should be worn its all new but the steering box, as for alignment ill prolly get it done in the spring because im putting the truck away in a week anyhow, i might try putting a new ragjoint in it and adjusting it and checking the fluid level. oh and it manual steering
Old 10-27-2010, 10:09 AM   #5
6768chevylover
6768chevylover's Avatar
Re: death wobble
do you have a steering stablizer on it?
6768chevylover is offline   Reply With Quote
Old 10-27-2010, 11:02 AM   #6
SCOTI
SCOTI's Avatar
Re: death wobble
Make sure the tie-rods are all tight.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 10-27-2010, 11:11 AM   #7
DaSchlange
DaSchlange's Avatar
Re: death wobble
Yeah, replace your rag joint, I just did in mine. It wobbles whenever you go around a curve?
DaSchlange is offline   Reply With Quote
