67/68 Core Support On A 69-72 Frame Q?
I've never crossed this bridge before.I'm building a '67 GMC-lookin' truck off a '71 frame.I figured the core support mounting kit should be a 67/68 type for the correct bushings to get the right height off the frame.I'm wondering what people do about the bigger holes in the frame brackets on a 69-72,since the 67/68 washers are about the same size as the holes.I figure just find bigger diameter fender washers or make plates.Is there a simple commonly done solution I don't know about?
VA72C10
![]() Join Date: Mar 2008
Re: 67/68 Core Support On A 69-72 Frame Q?
good question and probably FAQ fodder when it's answered
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
Anythong can be done,right?
![]() Join Date: May 2006
cut the '69-'72 rubber mounts down to the proper thickness, which is about 3/4" compressed
Burnouts are therapeutic
from what I have read here you are suppose to match the bushings to the frame and not the sheetmetal. 69-72 frame uses 69-72 bushings regardless of sheetmetal.http://67-72chevytrucks.com/vboard/s....php?p=4243502 here's a link to a post on similiar question.
1969 CHEVELLE SS 1972 C10 ALMOST DAILY DRIVER 1968 C10 RUSTBUCKET (MISSION IMPOSSIBLE) 1972 PONTIAC LEMANS CONVERTIBLE (WIFE'S CAR) "My wife and I were happy for twenty years. Then we met." - Rodney Dangerfield "The difference between genius and stupidity is that genius has its limits." - Einstein |
That one answer that says all supports are the same is wrong.The 69-72 core supports are shorter top to bottom.This is due to the 67/68s having a splash pan,I believe.I've been told by experts to go with what core support you are using.Cutting down the later bushings does sound like a good way to go.It figures I'd end up with 2 67/68 mount kits and no 69-72s.
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 10-27-2010 at 08:55 AM. |
Not sure if this will help but a 67-68 core support on a 69-72 will work for everything but your headlight alignment and bezel around the headlight. These will be to high, as mentioned because of the 69-72 are shorter top to bottom.
Now ask me I how I know... |
If I remember correctly, I built a '71 with a 67/68 front clip and ended using the 71's core support. I think I just drilled out the welds and removed the 69/72 headlight buckets. I might of messed with the mounting bushings, but I don't remember. I used the 67/68 hood latch. I do remember it was no trouble to do. Bolted on the fenders and the hood, I reused the headlight hardware, but had to shorten the adjuster screws.
Dano
![]() ![]() It ain't yours, if you didn't build it! |
![]() Join Date: May 2007
I put a 68 clip on a 72 frame and used 72 core support bushings with no problems....... sheetmetal lined up perfectly
