Old 10-28-2010, 12:41 AM   #1
isaacf
do i undercoat my cab or just paint it?
do i undercoat my cab or just paint it? i was planning to put a real thin coat of undercoating and then paint it balack. or i might just paint hugger orange to match the truck. i dont want it to look like i am hiding anything cause it is an almost rust free cab with factory rockers and floor boards
1969 chevelle 350 numbers matching
1971 chevy lifted 4x4 (the break up build) http://67-72chevytrucks.com/vboard/s...d.php?t=423605
1993 subaru impreza
1969 blazer cst 8" lift
isaacf is offline   Reply With Quote
Old 10-28-2010, 06:49 AM   #2
greguw
Re: do i undercoat my cab or just paint it?
I went with Por 15 on the bottom my build . I'm on the Eastcoast but brought my build back from California , its really tough to find rust free trucks around here .
I don't think I would use under coat , I have seen guys use the spray in bed liner like xline ... rhino liner is crap IMO .
Looks great buddy !
greguw is offline   Reply With Quote
Old 10-28-2010, 09:26 AM   #3
I just stripped one of my rustfree cabs to bare metal last month.I used two coats of Rustoleum Rust Stop primer and two coats of satin black Rustoleum.I'm not sure what color the truck will be and don't care if it matches since you never see it.I guess spray-on liner is good,but it scares me like undercoat and powder coat.If and when anything gets behind it,there it stays and eats.Paint crumbs off as the chip/scratch grows.Those other coatings are like a shell and I've seen worse damage because of those than without.
Old 10-28-2010, 09:43 AM   #4
82swampthing
82swampthing's Avatar
under coat because paint is not that strong up against rocks and sand and mud.trucks from the factory are under coated for a reason
R.I.P gm 1908-1986
1982 chevy k20,350,sm465,np205,10bolt and 14bolt s.f
82swampthing is offline   Reply With Quote
Old 10-28-2010, 10:37 AM   #5
OLDCHEV4X4
OLDCHEV4X4's Avatar
I have done it both ways. If its a driver> undercoat. If its a show truck> paint. (And dont hit any rocks or gravel).
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
Old 10-28-2010, 11:10 AM   #6
The one I just did is for a 2wd street driver.it'll see miles but an easy life compared to a stone tossin' 4wd.I still may hit it with the Duplicolor spray on liner.
Old 10-28-2010, 11:59 AM   #7
isaacf
ok thanks this truck will be my tow rig and to play in the mud truck
1993 subaru impreza
Old 10-28-2010, 07:09 PM   #8
isaacf
ok i just undercoated my cab and painted the bottom
1993 subaru impreza
Old 10-30-2010, 08:46 AM   #9
msgross
msgross's Avatar
They have tintable undercoating as well...lizard skin I think?. I plan on epoxy primer and Raptor bed liner.
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 09-08-2012, 06:34 PM   #10
andrewbarber
I have the same issue right now. I was thinking about getting my buddy to spray Rhino on it because the primer he uses in unreal and I have had him spray stuff and cant find a way to get it off. The only other issue is that it will not match my frame. The local Car quest here told me to use farm implement paint which is just single stage no hardner. He said it is the same thing as chasis black.
andrewbarber is offline   Reply With Quote
Old 09-08-2012, 09:53 PM   #11
69GWC
I would never undercoat anything again, my Nova is done and I had a tranny case get blown open and that tranny fliud turned the undercoating to tar or something along those lines.
I would use bedliner or the POR 15 .
Maybe with paint on it then it might not be effected by fluids but without it sure will.
69GWC is offline   Reply With Quote
Old 09-09-2012, 01:44 AM   #12
andrewmp6
69gwc i think that happened because most factory style undercoating is rubberized.Its better then nothing but i like more of the modern kind or spray on bed liner.
Old 09-10-2016, 11:43 PM   #13
bhpainter
hows everybody\
bhpainter is offline   Reply With Quote
Old 09-10-2016, 11:48 PM   #14
bhpainter
working on my 1967 all thats left is blast the cab everthing else done and prime takes time and money money money
li
eft
Old 09-11-2016, 12:38 AM   #15
69chevytrucker
69chevytrucker's Avatar
i did bed liner on both sides of my floor that way nothing can hurt it
69chevytrucker is offline   Reply With Quote
Old 09-11-2016, 09:31 AM   #16
fast&low
I wire wheeled it then 2 coats of primer 2 coats of paint then sprayed 3M undercoating.
Did it 2 years ago looks as good as the day I did it & it's my DD
fast&low is offline   Reply With Quote
Old 09-13-2016, 10:42 PM   #17
ripper70
ripper70's Avatar
I sand blasted it then POR 15 and rhino linered it
1970 K20
1967 Blown Stepside
2016 Chevy 2500 Duramax
1989 Jeep Cherokee
1995 S-10
2014 Infinity Q-50 AWD
1970 Chevy K20 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=634164
1967 stepside rebuild
http://67-72chevytrucks.com/vboard/s...d.php?t=684913
Shop build http://www.garagejournal.com/forum/s...d.php?t=225559
ripper70 is offline   Reply With Quote
Old 07-28-2017, 11:54 PM   #18
stevenfromtexas
stevenfromtexas's Avatar
wire wheeled and POR15-ed
stevenfromtexas is offline   Reply With Quote
Old 07-29-2017, 12:18 PM   #19
stevenfromtexas
...probably rotated....sorry
