Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 10-30-2010, 12:46 AM   #1
dbmx66
got that drag steering column, 14 point cage conversion and motor plate
column is in, cage is still in the process, and motor plate is being taken to my shop to get machinined. also got all my wiring s*** and a full set of fresh auto meter ultra light 2s. pictures sooon. just thought id keep you guys updated.
just got finish welding and motor this stuff, and the rest of the wiring and itll be done, after almost 3 years. so excited, just cant rush it.
dbmx66 is offline   Reply With Quote
Old 10-30-2010, 03:47 AM   #2
Super73
Super73's Avatar
Re: got that drag steering column, 14 point cage conversion and motor plate
What colum did you go with? Did you make one?
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 10-30-2010, 09:42 AM   #3
dbmx66
i just got this whole setup, u-joints, column, quick release steering wheel thing and a steering wheel and mounts, i thought it was good deal
its like one of those ones you see in tube chassis cars, it looks like a little tube haha
http://www.swracecars.com/store/Door...-372COMBO.aspx
Old 10-31-2010, 09:06 AM   #4
djracer
djracer's Avatar
This thread needs pics!
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 10-31-2010, 11:21 AM   #5
dbmx66
im workin on it hahaha the motor plate still in my shop, hopefully ill finish machining it monday or tuesday. maybe ill go down today and snap a few pictures
Old 11-22-2010, 11:10 AM   #6
bravo
bravo's Avatar
pics????????
bravo is offline   Reply With Quote
Old 11-23-2010, 01:30 AM   #7
dbmx66
here are some, theres alot more done sinces these, even tho these are # weeks old. haha
Old 11-23-2010, 11:48 AM   #8
softballnrd27
Always a work in progress
softballnrd27's Avatar
Where did you get the cage and what are you going to do in the dash area? Are going to re-install the factory metal piece or go with something different?
USMC Retired
Never trust a man who can't laugh at his own fart!
2010 Silverado Crew Cab
73 SWB 5.3/4l80e
Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=695168
softballnrd27 is offline   Reply With Quote
Old 11-23-2010, 04:23 PM   #9
dbmx66
i got the cage at s&W
and im not putting a dash in,
i making a billet gauge panel out of 7075 aluminum.
with billet brackets that clamp onto the dash bar and where the plate gets bolted to which spaces the plate out 3.25 inched from the bar.
i finished the plate, im working on the brackets now, i have the program written on the one cnc mill.
i sanded the plate at 40, 80, 120, 220, 400, 800, 1200, 2200, 4000 grit, then polished, its a straight mirror.
the only pics i have are are my phone and i dont know how to send them to my computer.
Old 11-24-2010, 07:46 AM   #10
softballnrd27
Can the roll cage be installed with the metal dash still in the vehicle? I guess if I cut it out I could just install an older style dash.
USMC Retired
73 SWB 5.3/4l80e
Build Thread:
Old 11-24-2010, 11:27 AM   #11
bravo
bravo's Avatar
real nice!!
Old 11-24-2010, 07:38 PM   #12
dbmx66
Originally Posted by bravo View Post
real nice!!
thank you sir
Old 11-24-2010, 07:39 PM   #13
dbmx66
you could prolly get away with cutting a hole in the metal part and slotting the plastic part.
Old 11-24-2010, 07:54 PM   #14
kpeztruck
kpeztruck's Avatar
The chassis shop that I use, cut a hole in the metal portion of the dash, then I notched the dash pad. It turned out really clean, and gives you more room to get in and out of the cab. Mine also has a funnycar cage, so space in the door opening became a premium. Paul Baxter
kpeztruck is offline   Reply With Quote
Old 11-24-2010, 08:03 PM   #15
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Very nice! I used the same type of column in my corvette. It is a really nice piece for the money.
Ryan
1969 Chevy milk truck
Old 11-24-2010, 10:38 PM   #16
dbmx66
it def is. its was super easy to install as well
