Old 03-02-2003, 09:46 PM   #1
alta-aj
Temp. Gauge Input?
I have a 79 400 in my 72 Jimmy. Ever since I installed it, the temp gauge hasn't worked. In fact, I'm not even sure if it worked before the engine changeout occurred.
I took the sender out today and put a flame to it and the resistance decreased from about 3.4K ohms at about 65 deg. as the temp increased. So, seeing I had responsiveness from the sender, I hooked the (dark green) wire from under the hood back up, made sure the sender was grounded, applied the heat again and still, no response at the gauge.
Can anyone tell me what the input to our vintage temp guage is (in case the 79 sender is incompatible) and what the range of the input is?
Any other suggestions as to what may be wrong?
Thanks for the help.
alta-aj is offline   Reply With Quote
Old 03-03-2003, 03:25 AM   #2
alta-aj
ttt
Old 03-03-2003, 04:37 AM   #3
TERRYP
GYRO GEARLOOSE
TERRYP's Avatar
Sender sends 0-90 ohms for a guage. Your sender should be a one wire unit, not 2, that's for idiot lights. Oil pressure, furl and temp use same range, (although 90->0 or 0>90 depending on the use. i keep a gas tank sender around to check guages.
Nevada City, CA
Everett, Washington
57 3/4 rat, 235, 3spd
66 C-10 Panel, SWB. 350 from '68, 200R4 tranny, 3.07 rear ratio, restoring
68 C10 LWB 350 4spd, 4.56 rear dump runner
82 Camaro, 305, THM-200-R4
84 Monte Carlo 305 TH350, land tuna
85 Tercel SW, snow runner
DISGRACED OUTLAW MEMBER OF THE DRUM BRAKE CLUB
TERRYP is offline   Reply With Quote
Old 03-03-2003, 05:12 AM   #4
Southpa
Southpa's Avatar
Engine block to frame grounded? Should be one ground strap on each back corner of the motor to the frame. And then frame should be grounded to cab near the middle mounts, I think. The one wire from the gauge to the sender is just a part of the connection. The ground straps should complete the circuit.
1970 GMC 1500 Custom
Original 350/TH350
Victoria, BC, Canada
You can wish in one hand and crap in the other.
See which one gets filled first.
Southpa is offline   Reply With Quote
