towing capacity question
Anyone out there know what the tow rating for a 68 Chevy C10 would be? I have towed our travel trailer with the truck and it did alright but I wonder if it is rated for a trailer that big.
1968 Chevy - 292 with a powerglide |
Where's my beer?
With my '71 I have towed somewhere close to 7000 lbs including the trailer, and it pulled it just fine, you just gotta have enough stopping power to stop the whole thing, because believe me is not easy
Paul How do you make the invisible, visible?.........You take it away. |
its all about the +6 inches
I have been trying to locate official numbers for this. I know some states make up there own rules, but I want to find some official GM lit on this.
from 69 dealer data book
Senior active founding member. 70 3/4 ton GMC Suburban 4x4 250/4 spd. 71 1/2 ton Suburban Chevy 4x4, 350/350 72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane 2005 FLSTSCI Harley Springer 85 FXSB Harley Lowrider 72 Triumph 650 Bonneville 5spd "Poor people don't have hobbies" Quote from wife. |
Re: towing capacity question
Hi Rod,
Would you happen to have this data for 1970? I have a 1970 C20 Custom Camper with 350/350 and 4.10 gears. Thanks!
Lance Top's Vintage Trailer Works 1970 Custom Camper/20 "Jenny" 1972 Airstream Ambassador "Abby" |
1970 Page on trailering GCW.
1970 gcw
Does anyone have info on a 68 K20 Panel/Suburban? All I have seen here is just the 2WD C10/20s.
Is there info on the 4WD 3/4ton models? 68 would be preferred but anything from 67 to 70 (with 4 wheel drum Brakes) would work. If you can send me info on this to k20pu@hotmail.com I would really appreciate it! An entire towing guide would be awesome for the 68 model year! Ralf
78 Chevy K20 Custom Deluxe, build: http://67-72chevytrucks.com/vboard/s...d.php?t=612104 68 Chevy K20 Panel truck, build: http://67-72chevytrucks.com/vboard/s...41#post7263441 |
Awsome Rod...thanks
Does that include burbs too? Or do you know? |
pt2 bigger
I hope Edmond sees this. He was trying to get this info about a month ago.
So was dutchburb I think.
Thanks very much for pointing me in the right direction 68 Suburban .
Rod ,can you please mail me a higher quality scan of both these pictures you've posted? I need a good readable print for this if I want to go the inspection and get it on my registration papers. I know Dutchburb will also be very happy with this information. Thanks in advance. ![]() Cya, Edmond ![]()
1971 Chevy C/20 Longhorn, 350/TH400, Edelbrock Performer, IMPCO 425 LPG Carb 1974 Chevy Camaro Z28 (Original) ------------------------- Capelle a/d IJssel, The Netherlands |
Rod, what publication is that in and is it still available?
72 3/4 4x4 350 4spd 72 3/4 4x4 350 auto 2004 Duramax Silverado 4x4 2006 Duramax Crew cab 4x4 2010 Harley Ultra Limited 2011 Harley Street Glide |
#15 |
14.1 @ 96MPH
Dang, 9500lbs combined for a C10 with a 350 and 3.73's?
![]() That's a good two tons of stuff and then some over the truck's weight!!!
Project1970 - LS1 Swap Complete! ![]() |
#16 |
Roughly equal to a modern mid-size car on a two-axle trailer. My 'Burb has logged many miles (in the thousands) towing Corvettes (2,900-3,500 lbs.) on a 16 ft. open trailer.
Alex V. ------ 1967 C10 Suburban, 350/NP435, Green/Green, PS, PB, HD cooling, charging, shocks, and springs. 1985 GMC C3500 SRW, Sierra Classic, 454/TH400, white/blue. |
#17 |
EDMOND tow capacity
I can get a better scan possibly... shoot me an email if the one I sent you is not good enough... I can get the same data from a 69 , 70 or 72 data book I have. These are from dealer data books.. and not everyone has one of those. hard to get... but sometimes up on ebay... but pricey... but they're good resource material definetly.
I sent an email of the scan to an email addy connected to your web site... not sure if thats what or where you wanted it sent. Rod
#18 |
OldSub,
I had a friend that pulled a completely disassembled B25 bomber from Lakefront Airport in New Orleans to Petal Miss. It was on a trailer and he used a 68 SWB stepside 6cyl with 3spd on column. He drove the truck for several years afterwards. This is just to show what they can pull. EdB |
#19 |
Recovering Truck Driver
Tow Capacity......I pulled 5300 lbs on the sled with my 72 K-10....hehe
67 K-20 350, SM465, Eaton rear, 4.56 no spin option 00 Dodge 2500 4x4, 24V cummins, 5 speed Chad South Central Nebraska |
#20 |
Thanks Rod for sending me the better scan of the page.
I hope it all works with registration.... ![]() Cya, Edmond
#21 |
#22 |
Way to go guys. I knew the info was out there somewhere Edmond. Never did find that towing brochure I read about. Nobody has one. This should be what you fellas over there need. Nice job Rod.
#23 |
I have the towing brochure too. Just trying to figure how to compress jpeg's so I cand send that to Edmond also.
Here's what the cover of a trailering brochure would look like.
#24 |
back
#25 |
one of the inside pages of info
