11-04-2010, 10:04 PM | #1 |
Wood floor to steel floor?
Looking for thread to replace short step side wood floor with steel floor on 1957 chevy truck.
509nat |
11-04-2010, 10:51 PM | #2 |
Re: Wood floor to steel floor?
I did this in my 69,I found a 80 something F@#D truck that had a nice floor in it.then got the measurements from my bed.Seems like it was 55" x 74" took a plasma cutter and cut away.Made the neds a lttle longer so I could grind them smooth and make it look nicer as you will see the 2 ends (tailgate and header)the sides will be covered up by the angle strips.Then I coated it up with some Herculiner.I went to Home Depot and got some carriage bolts and mounted it to the cross sills just like it allways was.Will more than likely do it to the Apache
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327/4L60 |
11-12-2010, 10:01 AM | #3 |
Depending on wether you are hauling or not a sheet of polished diamond plate looks great as a bed floor.
11-12-2010, 11:37 AM | #4 |
i think the 1990 stepside bed floor might fit
11-22-2010, 01:53 PM | #5 |
Check out some of my old posts (search "bondobob"). I used steel replacement panels over a 1" by 1" square tube framework on my '57. It's raised in the front to clear a 20 gallon gas tank and the frame steps. Lot's of welding but I didn't want wood. FYI: I'm getting back on the truck project after a 3 year layoff. (Divorce, move, buy house, add to garage)
edit: Can't seem to find any of my old posts. Is this normal? Last edited by bondobob; 11-22-2010 at 02:00 PM. |
11-22-2010, 04:33 PM | #6 |
Hey Bondobob,
Your thread probably got moved here: http://67-72chevytrucks.com/vboard/f...play.php?f=205 |
11-22-2010, 07:25 PM | #7 |
I appreciate all suggestions and pictures!
509nat |
