11-04-2010, 11:38 PM | #1 |
thermostat housing gasket and sealer
where do i put the sealer? between the housing and gasket, manifold and gasket, or both?
........................ __ ............._______|__\____ ............|_({})______({})] ................(O)..........(O) |
11-04-2010, 11:40 PM | #2 |
'70 C-10 Primer
Re: thermostat housing gasket and sealer
Neither. Sealer isn't necessary.
"The difference between stupidity and genius is that genius has its limits." Albert Einstein |
11-04-2010, 11:44 PM | #3 |
get one of these.
Chuck 68swb Fleetside build ''Choncho'' http://67-72chevytrucks.com/vboard/s...d.php?t=374892 My trailer redo http://67-72chevytrucks.com/vboard/s...69#post5893869 Chuy my 59 bug http://67-72chevytrucks.com/vboard/s...d.php?t=653798 Putnam 87 GMC Shop truck http://67-72chevytrucks.com/vboard/s...d.php?t=707687 |
11-04-2010, 11:46 PM | #4 |
damn! just bought a 4.00$ tube of sealer. what is that loner, and where can i get it, and how much?
11-04-2010, 11:59 PM | #5 |
ya, I bought a Mr. Gasket chrome thermestat housing and the stupid thing leaks a lot! It sux! I tried putting a new gasket in there and still didn't fix it. Even tried filling the o-ring knotch with some gasket maker still leaks! I should find one of these o-rings and a new gasket and see if that works. I can't find my original thermestat housing either
11-05-2010, 07:19 AM | #6 | |
11-05-2010, 07:16 AM | #7 |
he posted a pic that has manufacturers name and part number clearly visable. what info dont you have???
71c-10 350/2004r/4:11 lowered3/4 longbed/dead by hurricane MEANING OF DEATH::::: SOMEBODY ELSE GETS YOUR STUFF DONT BELIEVE EVERYTHING YOU THINK TAKE MY ADVISE;I DON'T USE IT ANYWAY Last edited by cdowns; 11-05-2010 at 07:22 AM. |
11-05-2010, 12:30 AM | #8 |
you can buy aluminum ones from knechts
11-05-2010, 08:13 AM | #9 |
Parts and more parts
Over the years, I have used the T/stat housings that required gaskets and I had a lot of corrosion (Pitting) issues on my aluminum manifolds, due to them being made from a variety of trash metals. I now use billet T/stat housings that have O-rings in them and I have not had any leakage or corrosion issues. since everything is now aluminum, the bimetallic issue is not there. The O-rings work well and can be replaced if needed. If you are using an aluminum intake, then i would suggest a good billet housing. Then again if you are still using the factory intake, then a good gasket with the O-ring built into it works great. Felpro offers them to the parts outlets.
Frank |
11-05-2010, 08:18 AM | #10 |
I don't recommend the Mr. Gasket chrome therm. housings. I had one on my for about 3 yrs. I noticed a slight leak one day, and found it was coming from the side! Apparently, antifreeze is corrosive to chromed pot metal. I replaced it with a stock GM aluminum housing with only a gasket, no sealant.
ryans69chevy, remove the o-ring and place the housing on a perfectly flat surface and you'll see why it won't seal. The chroming process warps the metal. If you have access to some kind of disc or belt sander, you can flatten the surface to make it seal. Like I said above, though, you'll have to replace it in a couple years.
11-08-2010, 01:53 AM | #11 | |
Thanks for the suggestion! I actually did put it on a flat surface when I was changing gaskets a week ago and noticed it was't flat! So I tried looking for my original housing and couldn't find it. Junk yard will have to do. |
