11-05-2010, 07:39 AM | #1 |
Cause of hard brake pedal?
The brakes have been fine on my old truck until yesterday. Coming home from work the pedal got realy hard and it took some extra time to get the truck to stop. Checked the fluid level when i got home and it was fine. What would cause this issue?
11-05-2010, 08:04 AM | #2 |
Its a Truck Thing......
Re: Cause of hard brake pedal?
Power or manual brakes?
Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 69 C30 Former Motor Home, Flat Bed time |
11-05-2010, 08:07 AM | #3 |
sounds like an identical problem I had ... it turned out to be a bad booster.
11-05-2010, 09:57 AM | #4 |
Oh, so it stops like my truck does when in working fine?
Sounds like a bad booster to me.
'68 Dodge Dart 270, 225, 904, 2.76--"Lucy" 1996 Gmc 1500 Z71, 350, 4l60e, 3.73s 1995 Jeep Wrangler Rio Grande 2.5, AX5, 4.10s 1989 Toyota Pickup 22re, auto, 3.73 |
11-05-2010, 10:32 AM | #5 |
Sorry I didnt elaborate. Power brakes.
11-05-2010, 10:39 AM | #6 |
Check your vacuum connections to the booster first.
11-08-2010, 12:28 PM | #7 |
06-14-2012, 02:59 PM | #8 |
I am having the same problem with my 72 C30 just changed the master cylr.thought that was the issue but I'll check my hoses too. Does any know what kind of booster came stock on them??? And if it is connected to the power steering or the engine?
Posted via Mobile Device |
06-14-2012, 03:41 PM | #9 |
Old Skool Club
These trucks, okay most of the 1-ton and under, had vacuum power brakes. Once you get over a ton (C-40 and up, plus a few C-30's) they may have another type, but not necessarily. I don't have my book in front of me, and I don't want to go on record for having lied.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
06-14-2012, 06:33 PM | #10 | |
Fabricate till you "puke"
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
