house of chevy's
starting problem?????
so this is the first time this has happened i dont know what to look at first i went to a buddys house last night truck was running fine no issues turned it of got out then they needed me to move my truck to a different spot got in turned the key ther was nothing no clicking starter noise nothing so i figured it was the fuse that i had to chenge last time looked at it it was fine so i decided to enjoy the rest of my night went out side like 2 hrs later for ****s went over to the truck to c and it started perfectly fine hung out some more started it to come home got home turned it off tryed starting it again and nothing again i dont know if its the starter or siloniod what do you guys think
thanx
1987 m1028 cucv d30 ![]() 2001 chevy s10 2000 honda shadow sabre 1100 "it's going to be an interesting ride home" ![]() |
Re: starting problem?????
I say loose connection. Start on the battery terminals, clean them good with a wire brush. After that check the cables going to the starter as well as ground cables.
Kung Fu Master
![]() Join Date: Oct 2005
Start here with the basics first.
72 GMC SuperCustom 4x4 1972 Chevrolet Cheyenne Super 4x4 |
house of chevy's
only one come on i need more help lol
Getting Old; Going Broke
If it's only doing it right after you shut it off, could be the solenoid getting hot.
Why is every used 350 sbc out of a corvette? There's only two things that excite a man, expensive toys and real expensive toys. VEGETARIAN: That's an old Indian word meaning "I don't hunt so good." When the going gets tough, switch to power tools. |
In my experience, the following were replaced when I experienced this problem:
ignition switch neutral switch stater/solenoid What it needed: upper steering column rebuild. Very expensive guessing on the part of many "highly qualified" mechanics. |
#7 | |
Ignition switch- Sends a signal to a Relay that will power your starter, Its just a switch so as long as its sending power to the relay the switch is working (as long as you hear clicking). Neutral switch- That should just complete the electric circuit needed to send power to your starter, once again if you hear clicking that means it is functioning and the starter is getting power. Starter solenoid- I was under the impression when this did not work it would just kick over the starter motor without engaging the flywheel, making a zinging sound. 9 out of 10 electrical problems seem to be a bad ground. Thats exactly where I would start, making sure all your cables have good connections. All the cables. |
One shot, one kill.
I spent 33 years working for Chevy dealers all over upstate NY. This may really sound "backyard", but in the interest of speed, this is the way alot of us checked this problem. First we checked the B+ circut, then B-. Next, hook a test light to the purple wire at the starter and turn the key to start. If it lit, solinoid feed circut was good. If it didn't, backtrack up to the ign switch testing at each switch in that circut. Next (and this is the backyard part) have a buddy sit in the truck (or car) and hold the key to the start position, while he is doing that, give the starter a good whack with a hammer. LOL If this works, and it usually does, rebuild\replace the starter. jim
1984 K20 350M engine with 465,000 miles. Well, it's finally done!! Almost 2 years of work, but it was really worth the effort. Little stuff left to do is mount winch, wet sand & buff out and build belly pan\running boards. Body work takes lots and LOTS of beer!!!! God, Guts and Guns made America and God, Guts and Guns will preserve it! The worst thing you could do is get into my sights, but that don't matter, you'll never know it, cause you'll never hear the shot ![]() |
My old Z28 used to do that at the worst possible times! turned out to be a bad fusible link on one of the starter wires.
house of chevy's
i checked all the wires they seem to be okay i have power from battery to other things that are hooked up but now im thinking it might be the ignition switch cause i have no power for any thing that the key controles ie wipers radio how hard is it to change like tucsonjwt said would the nuetral saftey switch affect any of that thanx
#11 | |
![]() 76 Silverado, 2wd, long box, 350/th350, 3.42 posi, edelbrock performer 64cc heads, edelbrock 1405, 2101 intake, Hedman Headers, Comp Cam XE262 http://beerbreadbike.wordpress.com/ |
I had that prob. on my 72. Would only do it when it was warm all my wires cables looked and tested good. Then one day after running around town and it was really warm I popped the hood and the neg battery cable was SMOKING it looked fine, but when I took it off it fell apart.
house of chevy's
is it worth changing both at the same time
house of chevy's
so i picked up a new ignition switch today going to put it in tommarrow hopefully that is what the problem is i guess well have to wait and c
#15 |
God is good!
My Blazer used to do the exact same thing. Look at the wires on the junction block on the firewall. Make sure they are clean. Mine would start right away with only a wiggle of the wires that attach at the junction block. I never did fix that before I sold the truck.
Mando "It takes a smart man to know when he's stupid." -- Barney Rubble My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=430367 |
#16 |
house of chevy's
so i went out this morning and changed my ignition switch tightened my fuse box cause it was loose put it all back together still nothing so i decided that when it happened last time it was a fusable link so i thought may be the other three were bad ran to parts store bought three new ones changed the first one and it fixed the problem again so now im happy my truck starts again lol
