Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 11-08-2010, 10:55 PM   #1
Yellow76
Yellow76's Avatar
Would this compression work?
Number of Cylinders :8
Bore in Inches :4.030
Stroke in Inches :3.48
Rod Length in Inches :5.7
Static Compression Ratio : 9.98
Inlet Valve Closes ABDC : 39.5º
Boost Pressure in PSI : 0
Target Altitude 200
This gives me 9.19 dynamic compression with a .040 head gasket. Would this set up run pump gas (91)?
Yellow76 is offline   Reply With Quote
Old 11-08-2010, 10:56 PM   #2
Yellow76
Yellow76's Avatar
Re: Would this compression work?
With this cam http://www.lunatipower.com/Product.aspx?id=1984&gid=287
Old 11-09-2010, 02:05 AM   #3
Super73
Super73's Avatar
Curious how you are coming up with that static compression of 9.98 and DCR of 9.19..
To get a SCR of 9.98 with the info you gave you would need a total of 75 cc's IE 71cc heads and -4 cc pistons for a total of 75cc.. Could be 68cc heads and 7cc pistons but either way is that right?
I think you are using the .050 number to get 39.5* IVC.. With 268* duration at .006 and installed on a intake center of 106, I get 8.23 DCR. DCR needs to be measured when the valve is closed. I did not see an intake centerline on the cam card you provided so I guessed on a 106icl. A 108 would net 8.12 and a 104 would net 8.35.. All of those "should" be acceptable with pump gas.
Anything over 8.5 is questionable and anything over 8.7 I would really suggest not running 91 with.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
