Old 11-09-2010, 03:58 PM   #1
dano327
1959 GMC wiring
I have Installed a 350 with hei ignition in my 1959 GMC p/u, I was wondering if someone could help me out with the wiring or were i can find a wiring diagram. the harness is in good shape so I want to use as much of it as possible and also the new engine came with an alternator and i am not sure how to wire it in to the system. any help would be greatly appreciated.
dano327 is offline   Reply With Quote
Old 11-09-2010, 04:55 PM   #2
OrrieG
OrrieG's Avatar
Re: 1959 GMC wiring
Here is a basic original diagram. At home I have a more detailed one from the factory assy manual. The hei needs a switched 12v wire (does not go thru the resistor) looks like the one from the ING2 post at the ignition switch that does not go thru the resistor might work. Check it with a multimeter to see if it is getting constant 12V. Can't help on the alternator, depends on the type (single wire, multi wire with internal regulator, multi wire with external regulator). A search here turned up a number of threads but it depends on the type you have.
Old 11-09-2010, 09:09 PM   #3
JML55
JML55's Avatar
Re: 1959 GMC wiring
Here is a basic GM alt wiring.
Jean-Marc Lacasse
57 GMC
55 GMC
55 Belair
99 S10
http://67-72chevytrucks.com/vboard/s...d.php?t=316140
http://67-72chevytrucks.com/vboard/s...d.php?t=806011
JML55 is offline   Reply With Quote
Old 11-10-2010, 12:15 AM   #4
dano327
Re: 1959 GMC wiring
thanks for the help, I was able to fire it up tonight and will work on charging system tomorrow
