Old 11-10-2010, 06:15 PM   #1
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
ECE Gas Tank Install Question
Has anyone installed ECE's rear mounted gas tank. I want to do the install on mine myself and am wondering if I need a flaring toll ( they are on sale this week at a local parts store) to flare the gas lines before I hook it up.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 11-10-2010, 06:30 PM   #2
ms2335
ms2335's Avatar
Re: ECE Gas Tank Install Question
i used all stainless steel lines and an fittings for mine
65 Chevy C10 Short Fleet BBW 6.0L/4l80E
68 Chevy C10 SWB 6.0L/4L80E
84 Chevy C10 SWB 5.3/4l60E QA1 Suspension
ms2335 is offline   Reply With Quote
Old 11-10-2010, 06:48 PM   #3
Already Gone
Are you saying if you use ss fitting and line you do not need to flare the ends .
Old 11-10-2010, 07:28 PM   #4
huero
1969 Short, Fleet, and Beat
huero's Avatar
37 degree flare for an fittings.
45 degree double flare for what is originally used on our trucks.
huero is offline   Reply With Quote
Old 11-10-2010, 09:44 PM   #5
ms2335
ms2335's Avatar
I will take picture of what I done tomorrow and post for you. it is braided stainless steel hose with aluminum ends and fittings from summit
Old 11-11-2010, 02:31 AM   #6
swamp rat
swamp rat's Avatar
The only time you need a flaring tool is if you shorten an existing length if fuel line, its sold 2 ways.
In streight lengths from 1' on up to about 5 or '6' with flairs and threaded male nut allready on them. this line is hard er to shape and ya need a tubing bender for tighter bends.
The other option is a coil of softer fuel line that is a little easyer to bend by hand, it comes in 25' lengths, probably 20' and 30' lengths as well. This stuff ya need a flaring tool for so you can cut it to length, ya need to buy the threaded flair nut, slide it on then use the flaring tool.
I plumbed in my tank using the streight length stuff, i used 3 pieces of varing lengths and custom bent each length, used female couplers to thread them together
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 11-11-2010, 09:52 AM   #7
ms2335
ms2335's Avatar
[ATTACH][ATTACH]Attachment 654986[/ATTACH][/ATTACH]
this is how i decided to do mine. I cost more but i think it was easier because i did not have a bender or flaring tool
Old 11-11-2010, 12:56 PM   #8
Already Gone
Thanks for the pics and advice. I dont own those tools either so I guess I'll do what you did with your tank, use the braided lines. Is that a fuel filter you have in the line ?
