Old 11-11-2010, 09:29 AM   #1
drsergio
drsergio's Avatar
1969 gmc lowering kit/ disk brake update
Ok,did some kind homework and was looking at this company called POL
PERFORMANCE ON LINE )
They are on Ebay a lot with good feedback and they have great prices and shipping comb.
Any one heard any bad or good about this company ??
Wil get he spindles drop 2.5 / brake disc up , front lower springs and shocks plus the brake booster , rear lowering block, all for around $ 1000 bucks
will use 2.5 drop sindles ,,,,with 2" drop coils anmd KYB shocks
and only do 3" lower block on the rear ,,I like the incline looks
ty for any feedback
will wait to order for a few days
ty
drsergio is offline   Reply With Quote
Old 11-11-2010, 01:42 PM   #2
smn69
Re: 1969 gmc lowering kit/ disk brake update
ty for any feedback
ty
Don't know anything about the company, but 4.5 inches drop in the front and only 3 in the rear it will have a pretty good rake angle to it. If I remember correctly, the back sits about 2 inches higher then the front in the stock configuration. Also the 3 inch drop blocks will not give you a lot of clearance between the trailing arm and the ground (especially if you get a flat) if you are running 15 inch wheels. You can get a set of rear drop springs from 1 to 6 inches for about $100.00 from board vendors. You may also not need new front shocks if yours are still good. I think you can use up to a 2 inch spring drop and still use stock shocks. The drop spindles don't affect the shocks. Check the site vendors too, I bought my brake and drop kit from gmcpauls.com and got everything for under 1000.00.
smn69 is offline   Reply With Quote
Old 11-11-2010, 05:21 PM   #3
mrhino
I have used POL before. Straight from their website and from ebay, I like em' I would buy from them again. I think you could do better on the prices. you found so far. I also use CCP (Classis Performance Parts) Rockauto.com and Classic parts of America and usual advance, auto zone, Oreiliys, and of coarse ebay. between all of those you should be able to put together the parts you need cheaper than any of the so called Kits.
mrhino is offline   Reply With Quote
Old 07-21-2011, 05:44 PM   #4
drsergio
drsergio's Avatar
Old 07-21-2011, 06:51 PM   #5
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Add wheels to your budget.The stock ones wont clear disc brakes.Also,you want to replace any worn or marginal parts in the front suspension while you're there.Ball joints,bushings and tie rod ends will cause premature tire wear.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 07-21-2011, 08:38 PM   #6
drsergio
drsergio's Avatar
all done ,,,,the new wheels fit perfct
295 45 20 in back
245 40 20 front
Old 07-21-2011, 10:35 PM   #7
OARNGESI
OARNGESI's Avatar
Looks really good
70 SWB STEPSIDE
70 BLAZER
09 challenger
OARNGESI is offline   Reply With Quote
Old 07-22-2011, 07:35 AM   #8
drsergio
drsergio's Avatar
ty
just put for sale here
sad to let go
http://67-72chevytrucks.com/vboard/c...p?product=5581
