Old 11-12-2010, 09:47 AM   #1
duwem
duwem's Avatar
50 Cab ID Tag in Door Jam
Can someone post a picture of what the vin plate in the drivers door frame looks like in a 1950 Chevy 3100? Want to see exactly what one looks like.
Also, is it correct that back in 50, the vehicles were titled with the engine ID number, not the vehicle?
Thanks!
duwem is offline   Reply With Quote
Old 11-12-2010, 10:25 AM   #2
fine69
fine69's Avatar
Re: 50 Cab ID Tag in Door Jam
Ah, back then some states titled the truck by the engine serial number. Some states by the vin tag. Which was not very much info.
I ran into this when buying a 49 GMC panel off of Ebay. It was in Florida. Florida titled them by the engine serial number.
Lucky for me it still had the original engine in it.
The vin tag was just screw on to the door jamb on these trucks.
Try the www.jalopyjournal.com
Or the www.hamb.com
More info there than here on these.
Lots of guys here visit that site.
2008 Chevy HHR 1/2 panel.
1949 Chevy Panel truck(just sittin, waiting)
Board member #6
fine69 is offline   Reply With Quote
Old 11-12-2010, 10:15 PM   #3
WIDESIDE72
WIDESIDE72's Avatar
[QUOTE=fine69;4291090]Ah, back then some states titled the truck by the engine serial number. Some states by the vin tag. Which was not very much info.QUOTE]
This is the case with my 55 first series truck. What am I supposed to do when I swap the engine? There is a tag on the jamb now, but the numbers on it have nothing to do with the number on the title or engine, and someone used sheetmetal screws to attach it... I bought a blank tag and am considering stamping the VIN on it and installing it with rivets.
WIDESIDE72 is offline   Reply With Quote
Old 11-15-2010, 12:17 AM   #4
fine69
fine69's Avatar
[quote=WIDESIDE72;4292086]
Food for thought......Where did you get the blank vin tag?
Board member #6
Old 11-12-2010, 03:11 PM   #5
duwem
duwem's Avatar
Aww shucks, could someone move this to the 47-59 forum, newbie mistake.
Old 11-15-2010, 12:18 AM   #6
fine69
fine69's Avatar
I replied to it, and didn't realize it was in the wrong area.
I moved it for you.
Board member #6
Old 11-15-2010, 07:55 AM   #7
RootBeer 6117
RootBeer 6117's Avatar
This is the one on my 49 the numbers are stamped into it.It is on the drivers door jam. I have a 51 cab that the tag has been painted over I dont see any numbers at all.
RootBeer 6117 is offline   Reply With Quote
Old 11-15-2010, 11:38 AM   #8
mr48chev
mr48chev's Avatar
Thanks!
Many states did tite the mid 50's. I would believe that the thinking at the time was that the engine was the heart of the vehicle and the net worth of the vehicle.
My 48 came with an "engine change" title from Texas that the p/o had gone to the trouble to have done. That saved my bacon when I moved back to Washington and had to have the truck inspected here.
If I still had the original block from the truck and a title with that block number on it I would hang on to that block for as long as it took to get the truck done and get an engine change designation on the title.
Back to the original question. several vendors have duplicate door post tags but they are blank. One example here: http://www.classicparts.com/1950-Doo...ctinfo/33-012/
Each tag has the gross weight listed and a space to stamp the body (serial) number. That still won't do a lot of good if you don't have a title or don't have a damaged tag like mine to get the number off.
I'd say that no tag is better than a bogus tag. Back in the 70's no one gave it much thought when they took the tag off when they were painting the truck and quite often they got lost in the process.
Old 11-15-2010, 03:09 PM   #9
Dan Bowles
AD Addict
Note that the number that Mr48 put up differs by truck year. I think 47-49, 50-51, 52-3, and 54-5 so you need to match your year with the tag you are after! I just looked this up last night. A buddy is doing a '47 and had to get 33-011 according to the ratted old catalog I had.
Some were screwed, some riveted. They have rivets available as well.
Dan Bowles is offline   Reply With Quote
Old 11-15-2010, 06:03 PM   #10
Atomsplitter
Atomsplitter's Avatar
Here's a shot of my new-old tag that I riveted on.
I had one of those dog tag/bracelet engraving places in the mall do the lettering/numbers so it looks professional.
I just used the serial number that came with the Ownership as my tag was not legible.
Atomsplitter is offline   Reply With Quote
Old 11-16-2010, 08:46 AM   #11
duwem
duwem's Avatar
Cool, thats what mine looks like, except the PO sanded off all the stuff except the punched numbers because it has been painted over. Wish he would have left the paint on, bet some mild paint remover could havd taken the top stuff off.
Mine is titled under the engine number, but I would like to switch it over to the vehicle number.
Old 11-17-2010, 03:04 AM   #12
mr48chev
mr48chev's Avatar
Mine was uglier than homemade muckie when I had the truck inspected with who knows how many coats of paint on it. I'd leave the original until I had the truck inspected and then do a repro if you want to go slick and fancy. The inspectors just want to see the number on the plate with the original rivets in place.
Old 11-16-2010, 05:05 PM   #13
Dan Bowles
AD Addict
I think they are 5/16 stamps.
Old 11-17-2010, 11:25 PM   #14
sweet70beast
sweet70beast's Avatar
My Panel, 50 Chev, GMC and Bus has screws holding it in place. My 51 GMC and 54 Suburban has rivets.
1970 Nova 327/T5 (my 1st car)
1971 K-20 350/350/205 (winter DD)
1953 GMC Suburban
1968 Chevy Bel Air
1976 Chev C-10
1972 Skylark (suncoupe)
1 of 3943 made
sweet70beast is offline   Reply With Quote
Old 11-21-2010, 10:17 AM   #15
duwem
duwem's Avatar
My Door jam plate is held on with 2 screws.
Is there a stamped number on the frame of the truck? If so, where is it and how do I find it? Is that number the same as the engine number or the door jam number or neither?
Thanks!
Old 11-21-2010, 11:42 AM   #16
Dan Bowles
AD Addict
Thanks!
Frame number: No. There isn't one.
Old 11-21-2010, 11:49 AM   #17
duwem
duwem's Avatar
Looks like the 57's have a frame number. Did they start doing it in 55 or something?
http://67-72chevytrucks.com/vboard/s...d.php?t=428153
