11-13-2010, 10:31 PM | #1 |
can i move bed to the side ?
i noticed today that the front of my bed is not in line with the cab by nearly an inch . if i was to loosen the bed bolts would there be any play enough for me to move it to the side ?
thanks |
11-13-2010, 10:34 PM | #2 |
Re: can i move bed to the side ?
There is a little movement in the mounting holes. You can also loosen the 4 cab mount bolts and two core support bolts and move it over a little .
Frank
Born and proudly residing in a Red State ! |
11-13-2010, 10:39 PM | #3 |
thanks . im gonna try doing the bed first then the cab if its not enough .
11-13-2010, 10:41 PM | #4 |
How do the all the horizonal lines look as far as alignment?
Could you have a collapsing cab mount making the appearance the bed is off or a racked frame thats been in a little twisting bind?
03 Suburban Z71 Z71 98 GMC Yukon SLT 4x4 Yukon 86 M1009 CUCV Project Milverado 48 Willys CJ2A 48CJ2A |
11-13-2010, 10:46 PM | #5 |
havnt got underneath to check any mounts yet . only noticed it today while fitting a headache rack . ill take a look at that also , thanks
11-13-2010, 10:48 PM | #6 |
Chris
I don't think it'll move maybe 1/4 if that best bet would be the cab, it should be able to move more, just alot of work.
Chris GIT R DONE!!!!!! Check out all our rides, http://www.cardomain.com/id/benwa454 |
11-13-2010, 10:52 PM | #7 |
yeah Chris it does sound like a lot of work with the cab and dont really wanna mess with the core suppurt if i can help it .
its not that big a deal really , just thought if it was easy to do id have a go |
11-13-2010, 10:54 PM | #8 |
Robert Olson Transport
before you go crazy make sure the truck is parked on level ground....
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
11-13-2010, 11:00 PM | #9 |
11-14-2010, 12:45 AM | #10 |
Chris
yea the bed bolt holes in the frame have more front to back movement then they do side to side. I don't blame ya though, I'd be more worried about the cab ones, core doesn't seem to bad to me 2 bolts, and could maybe get to them and cut them off and replace if they broke, or at least fix them, drill them out or whatever easier then the cab.
11-14-2010, 01:25 PM | #11 |
There is a little movement, but when I had the box off mine I drilled new holes in front of the old ones and moved my box ahead to closeup the the huge gap between the box and cab as well as center it with the cab.
