11-15-2010, 06:06 PM | #1 |
God Bless America
Transmission Conversion
I own a 1972 Chevy C10 that has a three speed on the column. I drive on the highway a lot, so fifty-five miles per hour in third gear kind of pushes it. How hard would it be to put in a four or preferably five speed manual transmission?
Thanks!
1972 Chevrolet Custom/10...my first truck and first project. Semper Fidelis |
11-15-2010, 06:34 PM | #2 | |
Re: Transmission Conversion
Second choice would be an A833/MY6 which was a factory option from about 82-87. This is a redesigned Mopar car 4 speed that gives you an overdrive 4th gear. The main problem with this one is that it is scarce. Also, some of them have an odd bolt pattern that requires a bellhousing swap. Next, and probably easiest to find, is an S-10 5 speed. This one requires that you shorten the input shaft and bearing retainer or use an aftermarket spacer plate between the transmission and bellhousing. You will also need to shorten the driveshaft. There are other possibilities, like a Tremec TKO (aftermarket only) or a T56, but they will be more expensive and require more modifications to install. Ray
Live more responsibly. Eat lower on the food chain. Eat vegetarians. Last edited by raycow; 11-15-2010 at 06:35 PM. |
11-15-2010, 07:33 PM | #3 |
God Bless America
Thanks raycow! If I were to use an S-10 five speed, would shortening the drive shaft be difficult? Would the transmission have to sit farther back, in order to keep the rear axle where it is? Sorry if any of these are stupid questions, I'm fairly new to this.
Thanks! |
11-15-2010, 07:46 PM | #4 |
I used a setup from a 66 chevelle. bellhousing flywheel, clutch,muncie 4 speed, made a new crossmember. not a hard swap to make
11-15-2010, 07:57 PM | #5 |
God Bless America
Thanks 57larry, I'll consider a chevelle when I disassemble my truck.
11-15-2010, 11:12 PM | #6 | |
The S-10 transmission will bolt to your existing bellhousing, much as your 3 speed does now. The driveshaft needs to be shorter because the S-10 transmission is longer than your 3 speed. There is no need to move your rear axle. Ray
Live more responsibly. Eat lower on the food chain. Eat vegetarians. |
11-15-2010, 08:12 PM | #7 |
Big Red - Now its a SWB!
There is alot of info on here on the t5 (s10 tranny) swap, the only issue is that they won't take alot of abuse, anything over 300 HP is pushing it. There is also the NV4500 out of newer 3/4 ton and 1 ton chevys and dodges. Here are a few threads to look over to get an idea what's involved.
http://67-72chevytrucks.com/vboard/s...d.php?t=313954 http://67-72chevytrucks.com/vboard/s...light=T-5+swap
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread 41 3/4 ton (wife's)-flatbed, fully restored to original 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's |
11-15-2010, 08:13 PM | #8 |
Forgot to ask what engine you are running?
11-16-2010, 01:06 AM | #9 |
God Bless America
I have a Chevy 350.
11-17-2010, 12:13 AM | #10 |
Too Dumb To Know Better
A 4 speed from a car will not help you. The final drive ratio is 1:1 just like you have now. You need an overdrive transmission or a rear gear swap.
11-17-2010, 12:29 AM | #11 |
God Bless America
Is there any way that I can go five speed and have over 300hp?
11-17-2010, 01:03 AM | #12 |
Sure. You can use a Tremec TKO if you want a car type transmission or a NV4500 if you want a truck type (granny 1st gear). There is also a Richmond 5 speed OD (car type).
Ray
Live more responsibly. Eat lower on the food chain. Eat vegetarians. Last edited by raycow; 11-17-2010 at 01:06 AM. |
11-17-2010, 11:36 AM | #13 |
God Bless America
11-17-2010, 02:40 PM | #14 |
On second thought, better forget about the Richmond unless you have bucket seats. The shifter on the Richmond can't be moved forward like the one on the Tremec.
Ray
