Old 11-16-2010, 09:41 AM   #1
Frozen1010
Frozen1010's Avatar
Instrument panel on 90 'Burb
Hello,
I have a 1990 R1500 Chevy Burb, and I am considering doing a custom instrument panel. I have read that there are two types of Spedometers, one that has a mechanical cable and one that is electronic. I have not taken the dash apart yet to see what I have, but if it has the mechanical type, is it possible to convert to an electronic type? Dealing with an electronic signal is way easier than a mechanical one and doing the conversion.
Thanks,
Lou
Frozen1010 is offline   Reply With Quote
Old 11-16-2010, 10:46 AM   #2
HOGDADDY
HOGDADDY's Avatar
Re: Instrument panel on 90 'Burb
Autometer has everything you need but its not cheap. You will need the speedo and the sending unit (http://www.summitracing.com/parts/ATM-5291/) that attaches to trans.
HOGDADDY is offline   Reply With Quote
Old 11-16-2010, 07:56 PM   #3
iroc12valve
you have an electronic speedo already
I believe its 84 and newer had electric speedo before that was the old nylon bushing/cable design
1991 V3500 350TBI/4l80/205 D60/14bff - Crew long
1987 IrocZ-28 525 horse/567 Lb Tq 383
1976 K30 on 39.5s One wheel drive thanks to a np203
and some K5's lol
iroc12valve is offline   Reply With Quote
Old 11-16-2010, 09:03 PM   #4
RandyP
Getting Old; Going Broke
RandyP's Avatar
89 and down suburbans have cable driven speedo, for sure. 91 suburbans have electronic speedos, for sure. 90 model I'm not 100% on, but I'm thinking they are electronic. 81-87 trucks all had cable driven speedos in them.
Why is every used 350 sbc out of a corvette?
There's only two things that excite a man, expensive toys and real expensive toys.
VEGETARIAN: That's an old Indian word meaning "I don't hunt so good."
When the going gets tough, switch to power tools.
RandyP is offline   Reply With Quote
Old 11-16-2010, 10:18 PM   #5
joe231
joe231's Avatar
Yep what Randy said.
90-91 burbs, blazers, and crews are electronic speedo
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 11-16-2010, 10:57 PM   #6
Jonboy
Slots go on anything!
The break is in 90. All 4wd trucks had electric speedo, some 2wd. Easiest way to tell is to slide under it on the drivers side and look at the tailhousing.
1974 Jimmy- 5.3/4L80e/NP241
Jonboy is offline   Reply With Quote
