11-16-2010, 10:13 PM | #1 |
trailing arm differences
I was wondering if there were any differences in trailing arm length between long and short beds
11-16-2010, 10:24 PM | #2 |
Re: trailing arm differences
ALL trailing arms are equal in length and interchangeable.
11-17-2010, 12:52 AM | #3 |
thank you
11-17-2010, 05:37 AM | #4 |
the only differance is between 1/2 and 3/4, 3/4 just had some extra sheet metal tacked to it.
11-17-2010, 06:44 AM | #5 |
Where do you get new bushings, and how hard are they to change?
71 Chevy C10 Shortbed Stepside. LT1 with 4l60E. Just got back from painter, in assembly now. |
11-17-2010, 09:57 AM | #6 |
You can get the bushings at about any Chevy parts dealer. I got mine from Early Classic Enterprises (poly). As far as changing them out, the best way to get the old ones out is to burn them out. The new ones just push back in.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
11-17-2010, 10:09 AM | #7 |
I don't have an oxy torch, so I use the drill method. I drill into the rubber part with a 3/8" or 1/2" drill depending on what bushing. Several passes, side loading the drill many times. After a while most of the bushing will be in a pile of rubber chunks. Then go after the steel shell if there is one. There is less clean up, and no fire runs. ( I nearly lit up the garage when grinder sparks found some steel wool on the bench a few months ago. )
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
11-17-2010, 01:42 PM | #8 |
needs more $$$
When doing new bushings on the arms, are a poly type better than rubber?
1970 2wd Blazer |
11-17-2010, 01:45 PM | #9 |
I think so. You get better performance out of the polys....
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 11-17-2010 at 01:46 PM. |
11-17-2010, 01:47 PM | #10 |
I just got a new set of trailing arms from Early Classics with rubber bushings. The way I understand it, rubber has more "give" and allows more flex in the rear. Good for comfort, maybe not so much for handling.
'68 Dodge Dart 270, 225, 904, 2.76--"Lucy" 1996 Gmc 1500 Z71, 350, 4l60e, 3.73s 1995 Jeep Wrangler Rio Grande 2.5, AX5, 4.10s 1989 Toyota Pickup 22re, auto, 3.73 |
11-17-2010, 04:08 PM | #11 |
needs more $$$
Sounds good. I ask because when going over some bumps at a decent speed, it feels as if the rear shimmy's a little. It's got the extended panhard bar on it, so I don't think the rear itself is shifting, but I was hoping poly bushings would help this.
1970 2wd Blazer |
11-17-2010, 07:12 PM | #12 |
Junior Member
do you have a front stabalizer bar (sway bar)? it will help eliminate some of that feel
frontstreetcycle on Instagram |
11-17-2010, 07:43 PM | #13 |
needs more $$$
Nope...I sure don't. It astonishes me that this is true though because it's definitely my tail end that shimmys. I do plan on a front bar in the future, but still waiting on what I decide for the lower ca's before I take that plunge.
1970 2wd Blazer |
11-17-2010, 10:54 PM | #14 | |
Junior Member
Even with the stock used rubber bushings it is a HUGE improvement & my trailing arm bushings are stock & need replaced... The sway bar was the best $50 I have spent lately for my truck.
11-19-2010, 05:23 PM | #15 | |
11-17-2010, 11:03 PM | #16 |
Truck and auto performance nut
for those with a big bench vise or their own press....but w/o a torch...I just put mine in the press and pressed the old bushings out of the shell...and then new ones back in.
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
