11-18-2010, 10:51 PM | #1 |
"something witty here"
Steering shaft shortening?
I swapped cabs from a later model with no power steering and the shaft that goes from the column to the steering box is a couple inches big, is it possible to take this apart and cut it down to size? I loosened this one bolt but didnt want to break anything with knowing...
57 chevy 4x4 70 swb fleetside 4x4 68 burb 2wd: 71 burb 2wd: 350 4spd 71 lwb fleetside 4x4: 350/sm465/205/3.07 eaton posi rear 72 lwb fleetside Cheyenne 454/th400 1991 GMC V3500 CC 4x4 |
11-18-2010, 10:58 PM | #2 |
Cultural Infidel
Re: Steering shaft shortening?
check this thread, start at post 41, hopefully this helps.
http://67-72chevytrucks.com/vboard/s...=191143&page=2
posted via La-Z-Boy -Mark 1972 C-10 Fleetside 350/TH350 PS PB A/C Cab Sadly....Sold 1968 Short Fleet 350/TH400 PS PB Delivered by Fine69 Also sadly Sold! It may be that your whole purpose in life is simply to serve as a warning to others. A man is not complete until he is married -- then he is finished. Last edited by Piece of Work; 11-18-2010 at 10:59 PM. Reason: forgot link |
11-18-2010, 11:25 PM | #3 |
Thanks that looks like it will help, Ill try and see what I can do in the morning.
11-18-2010, 11:40 PM | #4 |
The Older Generation
Here are a couple of threads that might have some info you can use also... http://67-72chevytrucks.com/vboard/s...d.php?t=133937 http://67-72chevytrucks.com/vboard/s...d.php?t=210459 LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 11-18-2010 at 11:47 PM. |
11-21-2010, 02:05 PM | #5 |
Thanks LockDock I drilled out the plastic and it still wouldnt budge, then I hammered like you said and it slid up real nice.
One more question tho, when you put the steering wheel back on, do you use the nut that holds it on to pull the wheel on as well?
11-21-2010, 08:52 PM | #6 | |
Yes, that has always worked for me.... LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 11-21-2010 at 08:52 PM. |
