Old 11-19-2010, 01:01 AM   #1
Critter
Future TOTM Winner
Critter's Avatar
Key cylinder removal with no key???
I have read plenty on how to remove the key cylinder from a tilt column but all the info assumes you have a key. I have an auto tilt column from a 1980 suburban that is in great shape but I don't have the keys for it. How do I change out the cylinder??? Or is it easier to just have a locksmith make me a new key to fit the cylinder that is already there? I searched and couldn't find anything, did I miss something???
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline   Reply With Quote
Old 11-19-2010, 03:04 AM   #2
Dru
Re: Key cylinder removal with no key???
Are you sure you have to have the key?
Its been quite a few years back since I've replaced any GM ignition cylinders, but having the key doesn't ring any bells as being an issue, the only thing I can remember that was pretty much a must have, was a puller for the wheel, and the little pullers for the tilt pins, the tilt pins night not even need to come out for ignition only, I cant remember.
Dru is offline   Reply With Quote
Old 11-19-2010, 06:47 AM   #3
S10Fan
Old Heap Driver
I've removed the lock cylinder without the key. There's a screw inside that holds the cylinder in place, remove it and out goes the cylinder. You can buy a new cylinder along with door locks that are all keyed the same, one key fits all three. I bought mine from a board vendor, GMC Pauls.
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
Old 11-19-2010, 09:20 AM   #4
motornut
78K & 79C Jimmys
motornut's Avatar
no prob with out the key,i've replaced them with the keys,same type used in many years (my 92 sunbird) as the burbs
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 11-19-2010, 10:03 AM   #5
James McClure
One shot, one kill.
Critter, Pull everything off down to the signal light switch, then pull the switch. You need not unplug it, just pull it up enough to move it down or to the left. In the shift bowls upper right quadrant, there is a torx or phillips head screw, remove it. Pull the cylinder straight out. Reverse to reassemble. jim
1984 K20 350M engine with 465,000 miles. Well, it's finally done!! Almost 2 years of work, but it was really worth the effort. Little stuff left to do is mount winch, wet sand & buff out and build belly pan\running boards. Body work takes lots and LOTS of beer!!!! God, Guts and Guns made America and God, Guts and Guns will preserve it! The worst thing you could do is get into my sights, but that don't matter, you'll never know it, cause you'll never hear the shotJim or Paladin whichever you choose.
James McClure is offline   Reply With Quote
Old 11-19-2010, 10:06 AM   #6
Critter
Future TOTM Winner
Critter's Avatar
Thanks! I guess I misread something. I thought you had to turn the cylinder at some point to release it. I appreciate the info.
Old 11-19-2010, 10:41 AM   #7
motornut
78K & 79C Jimmys
motornut's Avatar
don't turn anything when apart,look up and in hole to see the gear strip that moves the electrics further down the coloum,if that goes outa wack the key start/run/position will be off ...
John
Old 11-19-2010, 10:36 AM   #8
48cj2a
48cj2a's Avatar
If you want to keep the cyl and not buy a new one, once out - you can take the Key code number stamped on the side to any GM parts dept or a good locksmith and have a new key made.
03 Suburban Z71 Z71
98 GMC Yukon SLT 4x4 Yukon
86 M1009 CUCV Project Milverado
48 Willys CJ2A 48CJ2A
48cj2a is offline   Reply With Quote
