Old 11-19-2010, 01:24 AM   #1
mrsmothers
top speed question
Hi I have a 71 c10 with a three on the tree and a 350. I am about to get the truck back on the road in a few days and I was wondering, I do a lot of hwy miles do you think the truck in going to be able to run 70 to 75 with no problems or is that going to be pushing it? It also has the 373 gears in back.
mrsmothers is offline   Reply With Quote
Old 11-19-2010, 01:29 AM   #2
dan42
dan42's Avatar
Re: top speed question
70 to 75 will be pushing it a little. It would be fairly comfortable at 60 but depending on the tire size you'll be over 3000 rpms at 70-75.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 11-19-2010, 01:29 AM   #3
dwcsr
Hollister Road Co.
dwcsr's Avatar
Mine does.
Old 11-19-2010, 01:33 AM   #4
BossHogg69
motor exploder
BossHogg69's Avatar
Before I tore my '69 apart, it also had 3.73's, a TH400 trans, and a stock 454, and 275/60/15 tires. It would do 70-75 on the highway but it was a little buzzy and drank gas. 65mph was better, but it liked 60mph best and got much better mileage there.
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 11-19-2010, 02:09 AM   #5
Notrodder
I had a '76 3/4 ton, 350/350, w/3.73's and pizza cutter tires (235/85's), stone stock and got the thing going 120mph once. It was SCARY!, 'cause it felt like it was on 'tiptoes' with very little weight on the road.
If your rig is in decent shape, it should have no problem doing 70-75mph all day long.
Notrodder is offline   Reply With Quote
Old 11-19-2010, 05:18 AM   #6
swamp rat
swamp rat's Avatar
My truck loves doing 70/75.. 350/350 with 373's and 33's
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 11-19-2010, 07:29 AM   #7
rsavage
rsavage's Avatar
Just my opinion, but unless I had a motor that was fresh and built right, I wouldn't expect it to have any longevity if I was consistently turning it at 3000 rpms for extended periods of time on the highway. Engine rpm's in final drive are going to be dependent not only on gear ratio in rear end, but also on tire height. I've always felt that 24-2500 rpms was a good cruising rpm, but that's just me.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 11-19-2010, 07:34 AM   #8
cdowns
cdowns's Avatar
it all depends on how well you maintain it
Old 11-19-2010, 07:52 AM   #9
These trucks have run at hiway speeds all these years with no problem.The problem is people are used to vehicles with overdrive these days.I've run trucks with 4.10 rears all day long at 75 mph.It's a Chevy,don't worry about it.
Old 11-19-2010, 07:56 AM   #10
cam.man67
cam.man67's Avatar
70 to 75 won't do any favors for gas mileage, but I have an equally equipped '69 that has no problem running at that speed. 95 is about all I've ever done, due to traffic and the fact that I have manual brakes.
'68 Dodge Dart 270, 225, 904, 2.76--"Lucy"
1996 Gmc 1500 Z71, 350, 4l60e, 3.73s
1995 Jeep Wrangler Rio Grande 2.5, AX5, 4.10s
1989 Toyota Pickup 22re, auto, 3.73
cam.man67 is offline   Reply With Quote
Old 11-19-2010, 08:03 AM   #11
SWEET7T
Try spinnin 4 rear tars
SWEET7T's Avatar
My '70 has 3.08 gears, 255/70/15 tires and the speedo is dead on. At 75 I'm turnin right at 3000. Ran it that way for 2 years driving slightly over 400mi each way going to/from college almost once a month.
I've been from southern Arizona, to Idaho, Nevada, and everywhere in between in that truck. I never held a speed higher that 75, but I had spun over 100mph a couple of times.
SWEET7T
1970 C10, 2wd, LB, 307/TH350/3.08. PS, PB
SWEET7T is offline   Reply With Quote
Old 11-19-2010, 12:15 PM   #12
americanmusc1e
americanmusc1e's Avatar
I've got a 3.73's and I've driven mine in 3rd (direct drive) plenty of times due to problems with the 700r4 and it cruzes perfectly at 70-75 and 3600rpm.....
I've had it to 6000 in third gear too (120-130mph i'm not sure) and mine does quite well at high speeds though I wouldn't put that much load on my motor for too long
-- Josh
Instagram: @americanmusc1e
OLD SKOOL-- 1970 C10. 454/Th400/3.07 posi Build Thread
FARM TRUCK----1949 Chevrolet 3800 Power Wagon Hauler Build Thread
1999 4wd OBS Tahoe - daily.
DM me if you can't see photos i posted
americanmusc1e is offline   Reply With Quote
Old 11-19-2010, 12:44 PM   #13
lil hoodlum
lil hoodlum's Avatar
My '68 has a 350 smallblock, 3 speed manual, and I guess 3.75 rear end, and I consistantly run it 70 -75 mph on the highway. My truck seems to like it but with a 4 barrel edelbrock it does drink a lot of go juice. 60 -65 mph is much friendlier though. I have also driven it 80+ mph and I felt like that was pushing it too much. My motor is a bone stock and on its 12th year on a rebuild.
I sometimes wonder how much longer will it last.
lil hoodlum is offline   Reply With Quote
Old 11-19-2010, 05:16 PM   #14
prostreetC-10
My Carbon Footprint
prostreetC-10's Avatar
Try doing 70 mph with 373's and a couple of M/T prostreet 18.5 4 ply bias tires.....it's like doing 70 on hot air balloons. I can't wait to get my prostreet radials!!
prostreetC-10 is offline   Reply With Quote
Old 11-19-2010, 08:00 PM   #15
raycow
Back in the day, it was uncommon to get 100,000 miles out of an engine. Today's engines last longer because they are better of course, but taller gearing is also responsible for part of the improvement.
Overdrive was optional with a manual transmission until 69, and the buyers who were knowledgeable enough to order it were rewarded with increased engine life along with quieter running and reduced fuel and oil consumption.
Ray
Live more responsibly. Eat lower on the food chain. Eat vegetarians.
raycow is offline   Reply With Quote
