Active Member
![]() Join Date: Nov 2010
good morning. My name is Michael and i have worked for No Limit Eng. for going on four years now. Parts production manager is my title and keeping the shelves fully stocked is my game. When I get a chance i also get to do product installs. Last night a customer dropped of his tired 67 chevy shortbed. This moring I took it for a test ride around the block. I also took some ride hieght measurements and tire size so you guys get an idea of what i started with and what the end results will be. We will be installing some tubular upper and lower control arms, 2 inch drop spindles, 2 inch drop coils, new shocks, disc brakes, sway bars front and back, disc brakes out back, updated booster and master cylinder. To top it all off we will also be installing a power gearbox with new inner and outer tie rods, new center link, power steering hoses, new u-joints and a retro fit Ididit steering column. This should bring the trucks handling and braking up to par. So heres a few pics of the stripping of the front suspension. youll see the coils have been heated so much that they almost fell out when the vehicle was put on the lift. If anyone has any questions i will be happy to answer them around lunch when i have the front suspension back on. I will aslo post more pics throughout the day. michael
Active Member
Re: 67 chevy shortbed resurection
Couldn't fit all the pictures - here are a few more
67cheby
![]() Join Date: Sep 2008
cool, looking forward to seeing your products
Never Done?
![]() Join Date: May 2000
Subscribed!
Interested to see what you turn it into. |
I'm in... looking forward to your build!
Rex |
Tot Roddin'
Welcome to the board Michael!
Great looking build thread, can't wait to see it come together.
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
Active Member
alright have some more pics for you guys to look at. im hoping to get the arms on by the end of the day.
Active Member
time is money so i didnt take everything apart.
One day.....
Keep em coming! And welcome. Looking forward to finished product!
DZL1. Last edited by DZL1; 11-19-2010 at 06:37 PM. |
Master Procrastinator
cool truck, looking forward to the progress, had to bring out the torch to seperate the lowers, broke a couple forks
![]() 20 Duramax tow pig 68 2wd short stepper project 77 2wd short fleet beater 52 short project |
Welcome Michael and we all like great products and lots of picts!!
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
Restoration Virgin!
Go Michael Go!!!
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
VA72C10
![]() Join Date: Mar 2008
Subscribed...nice progress so far!
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
Roadtrip!
![]() Join Date: Feb 2003
Nice step by step you have going with pics. Keep em coming and welcome. Eric
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
#15 |
Active Member
more teardown pics
#16 |
Very nice, love the play by play pictures, good work
* 1968 GMC Swb - 98% done (current restoration) * 1971 Chevy Lwb - Retired Dump Hauler * 1982 K10 Longbox - New Dump Hauler |
#17 |
Active Member
more scrap metal
#18 |
Active Member
now the fun begins
#19 |
Active Member
so far so good no troubles with any of the components were using and im pretty satisfied with the quality of the components.
#20 |
67-72 parts collector,…
![]() Join Date: Nov 2002
Welcome!
Nice to have another member from No Limit Engineering. Subscribing to this one also.
#21 |
Restoration Virgin!
So Michael...does this 67 frame have the indention for the PS box, or are your going to use spacers or a BFH to make it fit
#22 |
Active Member
Yes there is a slight dimple in the frame for the gearbox but it is not deep enough for the new power box. My box came with the spacers required to bolt on without hitting the frame. there about a 1/4 inch thick. Brake rotors and calipers are mounted. New inner and outer tie rods, new idler arm, new pitman arm, factory center link from a 73-87 chevy pickup. The castle nut for new inner tie rods when bolted to the center link did not line up the the cotter pin hole. simple solution stack two to three 1/2 washers under castle nut to get cotter pin hole to line up. After gear box is centered and wheels are pointed straight forward make proper adjustments to inner and outer tie rods so they drop into the spindle without turning the wheels. This will get you close enough to do a tape measure alignment later on when its on the ground. After completed well take it to an alignment shop to get a proper alignment, but atleast it will be close enough to drive there. Now for the sway bar. The brackets were a little to long to keep the bar parellel with the chassis at ride height so i trimmed them slightly and opted to weld them on rather than drill holes. Much faster. Another small problem I have come across is the sway bar when bolted to the arm with the supplied end link contacts the outer tie rod. simple solution was to cut the spacer that goes between the rubber biscuits in half and reinstall. No more contact with tie rods. So far all of the products supplied form Performance Online along with the Mc Gaughys drop spindle disc brake kit have worked excellent. A couple of small problems but nothing you guys at home cant handle.
#23 |
Active Member
taking the old booster off is easy. The new booster uses the four factory studs on the firewall. bolts right on. The input shaft was a little to long for my truck so i crawled under the dash and took a measurement and trimmed booster shaft. bolted everything back together and installed factory shouldered bolt nut and cotter pin into the new eylet on booster. Now you will want to check the free play between the master and booster. when you press on the brake pedal you shoul be able to push about an 1/8 to 1/4 inch before you feel the master cylinder engage. If there is no free play there will be constant pressure being applied to the master and therefore constant pressure on your brake calipers. When you drive it will feel like the brakes are always on. Take a couple of minutes to pay attention to this small detail. Next start to plumb new lines to the front and rear brakes. I plumbed new lines in the stock fashion using all the factory clips on the chassis.
#24 |
Active Member
To finish up the front suspension and steering ill be installing a Retro fit Ididit steering column. Unbolt the old column and bolt in the new. Comes with wiring adapter to plug column into stock harness.
#25 |
Active Member
Yes the control arm hitting the ground during a flat is a concern of mine as well. when the vehicle is finished i will let all of the air out of one tire to see if it does hit the ground. I also have a concern with the steering stop on the spindle. With the tires off the ground AKA full droop when you turn the wheel the spindle stop hits the tube on the arm stopping it from making a full turn. This wont happen with the vehicle on the ground but lets say you hit a big bump in a hard right or left turn. If the vehicle rolls enough that stop could hit the arm and prevent you from making a correction or cuase a loss of steering. So i will be grinding about 1/4 to 3/8 of an inch off the bottom side of the steering stop to see if i can get it to stop hitting the arm at full droop. In the Performance Online catolog it states the arm is a stock replacement NOT a drop arm or drop pocketed arm. The reason im doing this build and forum. Is because i want to make sure the products we advertise and sell work like they state. If something doesnt work i will be able to notify the customer before hand.
