Old 11-19-2010, 06:49 PM   #1
gabe2000
1964 steering column swap
is it possible to replace a steering column from 1987 truck into a 1964 gmc truck??? Please help. I have gas tank, steering and other question.
gabe2000 is offline   Reply With Quote
Old 11-19-2010, 06:54 PM   #2
Clyde65
Clyde65's Avatar
Re: 1964 steering column swap
yes it is. Are you just going for a tilt addition or are you going from 3spd to auto?
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 11-20-2010, 03:22 PM   #3
gabe2000
i am going to auto and tilt column. I will post pics laters but I am new to this. I am been working on my truck for 6mos. I removed the cab myself, swapped the front end to disc brakes. i completed all of the welding, body and most bondo work. I am having a hard time with bondo on the corners and cruves fenders.
Old 11-24-2010, 06:36 PM   #4
gabe2000
I am a newbie here. Haven't posted my truck pics but will soon. trying to keep this post alive. thanks
Old 11-24-2010, 06:38 PM   #5
Clyde65
Clyde65's Avatar
very nice!, ya got some pix of what you started with? Keep us posted!
Clyde65
Rebuild of Clyde
support our troops!
Old 11-24-2010, 11:44 PM   #6
Greshampiglet
I put a tilt column out of a 78 chevy blazer with a factory floor shift I'm a back yard mech' and it took me about 3hr not busting my butt all the wiring is the same color code was really easy and eveything works "YEAH"
Greshampiglet is offline   Reply With Quote
Old 11-26-2010, 03:44 PM   #7
gabe2000
maybe on sunday i'll post
Old 11-29-2010, 01:19 AM   #8
gabe2000
Like i said i am new to this. the exprience i have is brake jobs
Old 11-29-2010, 01:25 AM   #9
gabe2000
I am open to any suggestions!!! Iam using parts from te 1988 suburban: suspension, steeriing if possible.
Old 11-29-2010, 01:35 AM   #10
gabe2000
like i said iam having trouble with the bondo. 7months of work and iam getting stressed. bondo, steer column, gas tanks, the rear axle is the suburban.
Old 11-29-2010, 02:37 AM   #11
Captainfab
60-66 Nut
Looks to me like you're doing good with the bondo work. If I may ask, where did you buy the patch panel above the windshield? I know there are a couple members here that need that piece. The only ones I've seen are listed for the '60-'63's.
Old 11-29-2010, 09:58 PM   #12
nbrfd007
nbrfd007's Avatar
I think Top Bannana has them,
nbrfd007 is offline   Reply With Quote
Old 11-29-2010, 08:50 PM   #13
DPowers
One foot in front of the other
DPowers's Avatar
I agree= looks good
DPowers is offline   Reply With Quote
Old 11-29-2010, 09:50 PM   #14
bulldoze76
Looks pretty good so far.
bulldoze76 is offline   Reply With Quote
Old 11-30-2010, 04:44 PM   #15
gabe2000
the top piece from the top roof is from MCL 60-63, i motifty the piece to fit. Bending the ends to make it longer and , welding and bondo. I need to know if steering column (auto) from the suburban fit. I need to order your power steering plates.
Old 11-30-2010, 05:17 PM   #16
QBA
Proud Americano
uhhmmmm.the jack stand and bottle jack combo looks a little iffy
Tattooed Cuban Trailer Trash.
putting the cart before the horse since 1964.
QBA is offline   Reply With Quote
Old 12-01-2010, 03:14 AM   #17
Captainfab
60-66 Nut
The '87 Suburban column will work with a little bit of work. It has been done by many so it is doable. You'll need to get the wiring diagram for the column, and your truck, so you know which wires to hook up and where on your truck.
Thanks for the info on that upper patch panel. I wasn't sure how they would fit up on a '64-'66 cab.
Old 12-01-2010, 03:40 AM   #18
Bugeyev8
Bugeyev8's Avatar
on the body work...take your time get it close and then spray a high build epoxy...then get some guide coat and see what happens when you hit it with a block, get yourself good blocks and quality paper , hit it with as long as a block as will fit in that area, on the doors I use I believe an 18 inch, spray the guide coat and see where the paint still remains after sanding, thats a low spot..so fill it and block again, if you hit shiny metal...thats a high ..take a picking hammer(one with a semi pointed head) and lightly tap it down...again re block and see what happens...all it takes is time
Bugeyev8 is offline   Reply With Quote
Old 12-02-2010, 06:46 PM   #19
gabe2000
thanks. bondo takes alot of time!!!!!!!!....patience
Old 12-27-2010, 02:55 PM   #20
gabe2000
Re: Transmission crossmember?
I converted my GMC 64 to automatica trany. What crossmember should I use??? Any old cars or truck??? let me know. I am putting engine/trany back into the truck and installing inner fenders/doors. I am going to start block sand as soon weather gets better. The engine chevy250/350thm auto.
Old 12-27-2010, 03:07 PM   #21
DPowers
DPowers's Avatar
Some guys use a crossmember from a later model C10. I modified one from a late 70"s camaro.
There is also a cool idea here:
http://www.persh.org/pickup/700R4.htm
Old 12-27-2010, 06:25 PM   #22
gabe2000
thx.
