11-21-2010, 01:30 PM | #1 |
Truck and auto performance nut
Over 500hp.....3" exhaust...or 2.5"?
Need opinions on my exhaust system for my truck. Its a roughly 550hp LSx with 1 7/8" headers and 3" collectors/reducers. A buddy gave me some low use 2.5" turbo mufflers and is trying to get me to go 2.5" but my original plans were for a 3" system. There's really no room for an x-pipe (within the frame rails) so I had planned on running an h-pipe over/under the driveshaft yoke, mufflers in front of the CPP trailing arm crossmember with the pipes going thru the 3.5" oval holes in it. Not sure from there....exit out the sides in front of the tires with some ovals notched into the steps, or over the axle and dumped...out of sight.
I know I would probably get better torque out of a 2.5" system...but feel the motor might need the bigger 3" system to reach its potential while still being "muffled". Thoughts?
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
11-21-2010, 02:36 PM | #2 |
At the body shop.
Re: Over 500hp.....3" exhaust...or 2.5"?
Id say 3''
" That didnt make it any newer " " Dont antique the equipment " |
11-21-2010, 02:43 PM | #3 |
I have a vortec 454 and nowhere near 500hp and I went with 3" duals but I also have stock exhaust manifolds with a 2 1/2" - 45 degree angle bends coming off the manifolds then goes into the 3". Im always thinking about the future, and future upgrades will be better with the 3". I bought a 3" x-pipe exhaust kit but I ended up not using it cause I wasnt going to be able to get the 'x' part tucked high enough into the frame. So I just ran duals and dumped in front of the axle....
11-21-2010, 04:30 PM | #4 |
Mean Green
You should be able to run x- pipe easily under your truck. I normally Flange mine on the back side also to make the trans easier to pull out. I also say 3" Due to future mods.
The shorter the exhaust the louder is going to be. Longer the quieter its going to be.
427 SBC 683HP & 590ftlbsTRQ @ fly wheel. 60'-1.38 1/4-10.43 MPH-124.6 New ET current 4/2019 AKA MEAN GREEN. |
11-21-2010, 05:45 PM | #5 |
Run 3 inch all the way. bigger exhaust will not hurt the torque output. This has been covered a bunch in a lot more detail in some other posts but bigger exhaust will only help not hurt. Let it breathe. Any small amount of torque you could possibly lose from running bigger pipes is already lost in your case with the 1 7/8's primaries. Just run 3" it will run and sound better.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
11-21-2010, 05:54 PM | #6 |
Thanks all! You helped me confirm my original decision...and as much as my buddy wants to help...he can keep the 2.5" mufflers for another project. I'm going 3"!
11-21-2010, 07:46 PM | #7 |
The Engine Whisperer
2.5" 2.5" 2.5" 2.5"!!!!!!!!!!!!!!
11-21-2010, 09:31 PM | #8 |
now you know someone had to come in and buck the status quo.
11-21-2010, 10:23 PM | #9 |
hahaha yeah. Trust my advice
11-23-2010, 04:00 AM | #10 |
So with your line of thinking, I should have made more TQ with 2.5" over 3" right? Why didn't I with the 347ci motor making 449rwhp and why don't I now with the 418ci motor making 521rwhp? I'm all ears and always willing to learn why... Torque for both motors was more with the 3" ALL THE WAY THROUGH THE CURVE starting at 2,400rpm where I began all my pulls..
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 |
11-23-2010, 12:40 PM | #11 |
It's Better With Nitro
...fit the largest diameter exhaust you can.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
11-21-2010, 11:25 PM | #12 |
do tell.
this truck will be more of a "race" truck - toy....then any kind of "driver". I don't go anywhere daily.....so I don't have one of those DD things.
11-21-2010, 11:42 PM | #13 |
Go to the drag strip and see how many drag cars/trucks are running exhaust smaller than 3". Your engine is nothing more than a airpump, everyone in the racing scene is trying to make their airpumps breath better. Bigger valves, bigger cam, bigger exhaust, turbos, superchargers, ect to get it to breath better. Most will run open hedders or run cutouts on street machines to get the most out of their preformance. I think you need to worry more about getting a tire to stick more than worrying about how much more torq you can get with 2 1/2" exhaust.
There is no way I would put on a 2 1/2 exhaust sstem on my drag can and expect it to preform better at the track... |
11-21-2010, 11:54 PM | #14 |
The smaller pipe=more torque thing is a wives tale/myth. Put up some dyno charts etc and prove that 2.5 will be better. The header tube size does have an effect but by the time the exhaust is past the collectors it doesnt matter.
11-22-2010, 02:27 AM | #15 |
At the body shop.
prostreet68sb keeps preaching 2.5
show us why 3'' is so bad
11-22-2010, 11:23 AM | #16 |
I went with 3in on ls3.
I got 1 5/8 headers with 3 in collectors with an x-pipe and sounds amazing. |
11-22-2010, 01:37 PM | #17 |
hang on now....I never said I wanted to run 2.5" instead 3"...quite the opposite. I didn't want to go 1 5/8" and bought large tube headers for a reason. And I'll probably run open headers at the track (I prefer to hear my own motor over the one beside me)....I was just trying to confirm my thoughts and get my buddy off my back about running the 2.5". This truck will drive to and from the track with the occasional just because cruise...and I'd prefer to let it breathe over trying to restrain it. I like to let 'em run when I find an open byway...
now I see this is another one of those areas that folks like to debate....
11-22-2010, 02:10 PM | #18 | |
At the body shop.
11-23-2010, 01:37 PM | #19 |
3" Flowmaster universal kit w/h-pipe and 3" turbo mufflers (my preference) on the way and will be here tomorrow! I just love Summitt...its here 2nd day w/o while paying for air...just $8 for "standard ground" shipping. Going behind my DynaTech 1 7/8" - 3" long tube headers....should sound mean but we'll see!
and for anyone thinking I should have gone with 2.5" for "torque" reasons.....this truck won't pull or haul anything heavy. I'll build another truck for that someday. Consider this more of a "combo" truck seeing drag race and possible even track day/autocross road course style racing. For the occasional drive...it can have a "bit less then street manners"...it'll just add more to the fun. My fuel injected vehicles will be the "tame" ones.
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken Last edited by 68GMCCustom; 11-23-2010 at 01:42 PM. |
11-23-2010, 04:09 PM | #20 |
Once it's installed get a vid with sound so we can hear it...
11-30-2010, 02:19 PM | #21 |
11-30-2010, 04:55 PM | #22 | |
11-30-2010, 06:25 PM | #23 |
Big Red - Now its a SWB!
X2
Also I'm a little late for the debate but I woulda said 3"
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread 41 3/4 ton (wife's)-flatbed, fully restored to original 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's |
11-30-2010, 10:11 PM | #24 |
I think they are trusher's. Got them at a local autopart store.
Posted via Mobile Device |
11-30-2010, 11:40 PM | #25 |
Another option is to use 3" or 3 1/2" cutouts off the headers (run a short 3 or 3 1/2" pipe from header to cutout), then reduce and run 2.5" out of the cutout. If you have having clearance issues with larger pipe, or if their is a huge difference in pricing (although this setup will cost more in the end). This way you can run quieter mufflers for longer cruises and keep it tolerable, then have an open header type sound when you want to get crazy with cutouts open (the cutouts open will make the most power over any sized exhaust BTW).
Here is an example...
2007 TBSS 418ci AI CNC 243, Futral cam, ARH headers, RPM VI tranny, Vig 2800, 430awhp/426awtq 12.1 @110 2002 Camaro SS 346ci Heads/Cam/Intake ARH headers M6, Koni, UMI, magnaflow, DMH, Meizere, ATI, 456rwhp/414rwtq 1965 Chevy C-10 Stepside, 355, TH350, 3000 coan stall, 4.10...Going under the knive! http://www.hubgarage.com/mygarage/profile/28922 |
