Old 11-25-2010, 11:25 PM   #1
Rob68c10
What to keep off 72 for a 6 lug to 5 lug conversion?
Hey guys I will be going to pick up a 72 for the a/c cab and figured I may as well swap the stuff out for 5 lug. What do I need to keep off the front to convert to a 5 lug? I was thinkin about just unbolting the front crossmember and rolling it under mine.
Rob68c10 is offline   Reply With Quote
Old 11-25-2010, 11:42 PM   #2
VA72C10
VA72C10
VA72C10's Avatar
Re: What to keep off 72 for a 6 lug to 5 lug conversion?
using the entire front crossmember is the best way. Then the rear can also be swapped.
Old 11-26-2010, 12:27 AM   #3
68anniversary
I just finished doing this on my 68. I just unbolted the entire crossmember and installed it on mine. Did the whole swap in a day.
68anniversary is offline   Reply With Quote
Old 11-26-2010, 02:01 AM   #4
spike38
spike38's Avatar
Spike
spike38 is offline   Reply With Quote
Old 11-26-2010, 06:07 AM   #5
cdowns
cdowns's Avatar
saving brake booster with braces for it master cylinder and proportioning valve is all good stuff to have
Old 11-26-2010, 02:21 PM   #6
raycow
You don't need to swap the crossmember unless you want to. IMO, it is less work to unbolt the control arm shafts and take everything from there on out. Be sure to get the steering linkage too, because the tie rod ends are different.
Ray
Live more responsibly. Eat lower on the food chain. Eat vegetarians.
raycow is offline   Reply With Quote
