Old 11-26-2010, 02:02 PM   #1
bwkennedy
redo on vent windows
I am redoing my 66 Chevy, I am now doing the vent window gaskets adn windows. when I started the vent windows they had some sort of rivet holdin them in. I drilled out the rivet to replace the gasket. Now when I am reinstalling the gasket what do I use a pop rivet is too big for it. Any help would be appreciated. Thanks
bwkennedy is offline   Reply With Quote
Old 11-26-2010, 02:25 PM   #2
nhtc33d
Re: redo on vent windows
Are you refering to the pivot rivet or the rivets used to hold in the gasket?I just rebuild mine and i used pop rivets for the weatherstrip. You can buy the rivets that they used from the factory but you need a special tool to peen/flair out the rivet. Here is a great how-to write up that may help you.
http://67-72chevytrucks.com/vboard/s...d.php?t=351471 Good luck.
nhtc33d is offline   Reply With Quote
Old 11-30-2010, 01:21 AM   #3
jibbyjammin
get the origanal stuff plus tool for install for around 8 bucks from LMC
jibbyjammin is offline   Reply With Quote
Old 11-30-2010, 11:05 AM   #4
Clyde65
Clyde65's Avatar
Make sure the rubber is warm before you put them in the vent assy, it is best if you do the rebuild inside where its warm and I put mine in the oven on warm for about 5 minutes before I put them in. Then after that I did the rivets and such.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
