Old 11-29-2010, 09:59 AM   #1
rich67
rich67's Avatar
roamer
my c-20 2wheel has maybe not original, but original era straight treads on front. manual steer. it roams to the left and to the right pretty bad. would like to drive to work someday but think it would wear me the freak out in present condition as its 35 miles one way.im sure i need new rubber. any body have any good replacement tire ideas? and any further suggestions to help the roaming would be awesome. thanx rich
rich67 is offline   Reply With Quote
Old 11-29-2010, 11:58 AM   #2
Papa Smurf
Active Member
Re: roamer
since its a c-20 you need to check the rear wheels. I bought one once and it was all over the road. Turns out it had a locker rear with one 16" and one 16.5". give it gas it pulls one way, let off it pulls the other. Just a thought.
72 Sierra Grande 2500 BB
72 Sierra 2500, 42K miles, factory buckets
72 Cheyenne 20
72 Chevy SWB, Factory BB, Leaf Spring
Papa Smurf is offline   Reply With Quote
Old 11-29-2010, 12:02 PM   #3
Zeke's Garage
Zeke's Garage's Avatar
Re: roamer
Other things to look at are the ball joints, idler arm and tie rod ends. Plus check the play in your steering box. All that coupled with large oddly worn rubber in the front will cause all kinds of strange feelings on the road. Badly worn bushings in the A-arms can cause unsettling feelings as well, mostly during braking.
Shawn
Zeke's Garage is offline   Reply With Quote
Old 11-29-2010, 12:35 PM   #4
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
Re: roamer
I think tires will help, but the front end probably needs some attention too. Like mentioned above most probable culprits are ball joints, tie rods, and steering box/shaft, but also check the wheel bearings. Easiest way to check for problems is jack up one side and grab the tire in the air at 12 oclock and 6 oclock and try to rock it, if it has play then it is probably ball joint. Then grab it at 3 and 6 oclock and rock it if there is slack in it, it's somewhere in the steering system. If it has play when you rocked it both directions (up/down and side/side) then it could be loose wheel bearings or a combination of problems. Then, set that side down and try the other side. Obviously there is a little more to this, but this will give you and idea of what is going on.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 11-29-2010, 12:36 PM   #5
Jacfourteen
Re: roamer
Also I just thought of something else. Check to see if the bushings are good in the panhard bar, if they are sloppy they will cause the tail end to wag around as you drive.
Old 11-29-2010, 10:52 PM   #6
hayhauler71
hayhauler71's Avatar
Re: roamer
The rag joint on the steering shaft is probably shot. A new rag joint does wonders to steering feel.
Fuzzy
hayhauler71 is offline   Reply With Quote
Old 11-30-2010, 11:37 PM   #7
rich67
rich67's Avatar
Re: roamer
thanx folks. plenty of things to check. all of which will probably make better. old county truck. alot of gravel roads. 55000 original miles though.
