11-29-2010, 04:38 PM | #1 |
Tach Problems
I just took out a year old aftermarket tach and replaced it with a tach dash. But I realized that the rpm's are off when driving down the highway now. The tach reads about a thousand rpm higher than my aftermarket tach read. I have 4.10 gears with an automatic and now it says I'm doing over 5 grand going down the highway. Is there anything I can do to my tach or do I have to replace it with a new one?
01 Pontiac Bonneville SLE 62 Studebaker GT Hawk 72 GMC C20-327/th350 81 Chevy c10 84 Monte Carlo SS 70 Ford 3/4ton 4X4 Highboy 390/bedhoist 68 Mercury Cougar GT |
11-29-2010, 05:35 PM | #2 |
Formerly- 1972SuperCheyenne
Re: Tach Problems
Your tach dash for a v6 or v8?
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
11-29-2010, 06:02 PM | #3 |
Re: Tach Problems
The tach dash I got came out of a grain truck with a big block in it.
11-29-2010, 11:58 PM | #4 |
Re: Tach Problems
What kind of distibutor do you have? Some aftermarket distributors require a tach signal adapter to function with a factory tach, the signal is different for oe vs. Aftermarket!!
Posted via Mobile Device |
11-30-2010, 03:42 PM | #5 |
Re: Tach Problems
I have a standard hei distributer, but it has a hypertech coil in it. I'm kind of clueless. The only thing I can think to do is buy a new tach.......
11-30-2010, 03:56 PM | #6 |
Re: Tach Problems
Coil shouldn't matter, it's an hei which should put out the right signal, the tach may be for a 6 cyl, it is a GM tach right? if you know 100% it's an 8 cyl tach then it should work. If it is an original tach and it's reading too high it sounds as if you got a 6 banger tach.
11-30-2010, 06:09 PM | #7 |
Re: Tach Problems
Okay, well thanx for the information. I'll have to tear it apart this weekend and start looking around for another tach.
11-30-2010, 06:33 PM | #8 |
Roadtrip!
Re: Tach Problems
If it is not too faded, there should be a stamp on back of the tach head for 6 cyl or 8 cyl. There is also a small hole that has an adjuster in it. I have heard of people tuning them that way, but i have never done it. Keep in mind, these were never real accurate from day 1. It shouldn't be off by 1000 rpms though. Good luck.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
11-30-2010, 08:47 PM | #9 |
Re: Tach Problems
ya I couldn't remember so I looked in my pictures I took and it was an 8 cylinder tach. I'll try adjusting it a little to see if it helps, thanx
11-30-2010, 09:25 PM | #10 |
Tot Roddin'
Re: Tach Problems
I thought there was a different wiring harness for a standard coil vs. HEI. Am I wrong?
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
11-30-2010, 09:52 PM | #11 | |
Re: Tach Problems
Posted via Mobile Device Last edited by PCHRODS; 11-30-2010 at 09:54 PM. |
11-30-2010, 10:13 PM | #12 |
Cops, ha, catch me if you can!
Re: Tach Problems
You said you have 4.11 gears and an automatic; I am going to guess a th350. You can always do the math and find out if it’s the tach dash that’s off or the old one, maybe a bit of both.
Check out this link and enter your information and you'll get your correct RPM and Speed, http://www.pszweb.com/car/gears.htm
72 C-10 Stepper 350/TH350 3.73 in the back Edelbrock intake and Carb Hooker Comp Headers 275/60R15 on Rallies |
12-01-2010, 04:38 PM | #13 |
Re: Tach Problems
well thanx for the tips guys, the only thing I can think of is that I didn't buy a harness for the tach. It had the female connector on the back of the tach when I got it so I just made a harness for the tach using some regular wire hooked up to the distributer and fuze box. I didn't think this would affect it since it's still getting power, what do you guys think?
11-30-2010, 09:57 PM | #14 |
Re: Tach Problems
Another thing to look at!! Make sure the coil is getting a full 12v alot of time on originally equipped points vehicles they had a resistor wire on the coil feed that dropped the voyage down to 7 volts, you disnt say anything about sputtering issues so this has probably been long sense removed! Just a thought!!
