Old 11-30-2010, 12:54 PM   #1
spudz
spudz's Avatar
Is this a dually or a cab and chassis?
Thinking about buying this 79 chevy. Is it a dually or a cab and chassis??? has a 454.
2004 z71, 96 z71 on 38s, 88 Chevy k5 blazer, 4in lift. 84 swb project, 82 SWB project , 84 chevy 4x4 lwb project, 88 Jimmy beater/highschool ride. 79 c30. 99 tahoe 4x4 project. and a bunch of parts trucks..
spudz is offline   Reply With Quote
Old 11-30-2010, 12:55 PM   #2
63chevyll
gets board easy.......
63chevyll's Avatar
Re: Is this a dually or a cab and chassis?
cab and chassis,
see the distance from the cab to the rear wheels
63chevyll is offline   Reply With Quote
Old 11-30-2010, 01:04 PM   #3
Prerunner1982
Prerunner1982's Avatar
I don't know about the distance from the cab to the rear wheels (looks about right for a longbed to me)...but if it is a cab and chassis the rear tires will be closer together. If the flatbed is the same width as the cab then it is a cab and chassis since the flat bed completely covers the rear tires. If the flat bed sticks out on the sides (does not look like it does) then it would be a regular dually.
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 11-30-2010, 01:14 PM   #4
spudz
spudz's Avatar
ok I am gonna try an go look at it soon I will take better pics.. Basicly if rear end is same width as cab, its a cab and chassis. if it sticks out. its a dually.
Old 11-30-2010, 01:21 PM   #5
Pop's C-10
Pop's C-10's Avatar
cab & chassis
Pop's C-10 is offline   Reply With Quote
Old 11-30-2010, 01:41 PM   #6
spudz
spudz's Avatar
was talking to owner, it used to be a wrecker so cab and chassis makes since ... thanks!
Old 11-30-2010, 02:17 PM   #7
GM72K10
Next!
GM72K10's Avatar
If third digit in vin is a "B" (CHEVY) or "D" (GMC) its a cab and chassis, however in that era you could get a C&C in any wheel base
86 K30 CUCV M1028A1
86 K30 CUCV M1028a2 dually
86 K30 C&C 6.2 4:56s, 4M, 11,000 gvw, ex fire truck, now lowboy dump
More square bodies and CUCVs than I care to admit to
2020 Silverado K3500HD Work truck
GM72K10 is offline   Reply With Quote
Old 11-30-2010, 02:28 PM   #8
Rpratt
Rpratt's Avatar
If you try to bleed the rear brakes, and end up bleeding your knuckles instead....... its a cab and chassis.
the drums are very very close to the springs on the C&C trucks, the dually will have plenty of room.
Rpratt is offline   Reply With Quote
Old 11-30-2010, 02:31 PM   #9
spudz
spudz's Avatar
thanks everybody!
Old 11-30-2010, 08:36 PM   #10
spudz
spudz's Avatar
Went and looked at it. Pretty sure its a dually. As it says camper special. I am on the way home from looking at it. I will post more pics when I get home. Either way I am getting it. Bed is real nice. Little rust in drivers rocker panel. Electric windows etc. Hydro boast. Missing all the ac stuff. Here is the vin number if someone wants to help decode. Ccs339v121482
Old 11-30-2010, 09:30 PM   #11
80SPORT
80SPORT's Avatar
79 chevy 2wd 1 ton cab and chassis 454 assembled at Pontiac ,Michigan
Unit #121482
80SPORT is offline   Reply With Quote
Old 11-30-2010, 09:55 PM   #12
spudz
spudz's Avatar
Unit #121482
really cool.. i was thinking it was a dually because of the camper special thing and it looks like the rear end sticks out farther then the cab
Old 11-30-2010, 10:14 PM   #13
87 chevy silverado
JW were is that located? not wanting it. looks real familiar is why i ask.
87 chevy silverado is offline   Reply With Quote
Old 11-30-2010, 09:45 PM   #14
spudz
spudz's Avatar
Re: Is this a dually or a cab and chassis? NEW PICS!!
here are the pics and I got a few questions. In the pic of the front of the engine... Looks how that hose goes from the water pump to the intake.. Its a awefull angle. How is it supposed to be. also the pic of where the ebrake should be is this lever and like a valve. says its a hydrolic parking brake? how does this work.. I figure it was put in here when it was a wrecker. also, the big question, what would you pay for this.... I will list the pros an cons...
PROs
has a less then year old bed and its real nice.
decent tires with chrome simulators
454 that seems to runs good
newer holley carb and edelbrock intake
electric windows
none bent or rusted hood
has msd 6a box
nice exhuast
motor was rebuilt at some time in its life
has newer chevy steering wheel thats nice
new water pump, alternator, and starter
CONS
rusty drivers side rocker and some rust starting around the door openings and hinge area
has 81 and up front bumper that doesnt fit
awefull ugly paint.. looks to have been red and silver originaly
seat,headlinner,and carpet needs replaced or recovered
windows move slow as death
intake manifold has a small water leak in one corner requiring new gaskets atleast.
wiring is a mess!!! has a starter button and a seperate button for horn.. I HATE BAD WIRING.. plus is I have a ton of parts trucks to get parts and wiring from
All the ac stuff is gone.. I have most but no brackets for a big block.
the drivers side exhuast dounut is bad
Old 11-30-2010, 09:53 PM   #15
spudz
spudz's Avatar
more pics
Old 11-30-2010, 10:13 PM   #16
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
PROs
electric windows
has msd 6a box
nice exhuast
CONS
That intake hose was replaced with a piece of heater hose when it actually should have a formed rubber hose, that is why that hose is all disformed.
That brake valve should operate like this I think:
Step on the brakes, while holding the brake pedal firmly turn the handle on the valve and this will hold the brakes like a line lock. Tow trucks had this a lot to help hold the vehicle where as the normal park brake just wouldn't do the job.
As far as what I would pay for it, IDK. With a good running 454 and that bed, I think it would be an ok deal at $1200-$1500 the way the economy is right now. If you really wanted it and can live with the problems you know you will have to fix, I wouldn't go more than $1800. But that is my .02. Good luck.
Ryan
1969 Chevy milk truck
Old 11-30-2010, 09:27 PM   #17
Dieselwrencher
According to the VIN and the info posted earlier, it isn't a cab and chassis. The truck looks really nice. Nice score.
Ryan
Old 11-30-2010, 10:06 PM   #18
Dieselwrencher
How much room is there in between the rear tires and the leaf springs? Maybe take a pic from the front looking in that area.
Ryan
Old 11-30-2010, 11:00 PM   #19
spudz
spudz's Avatar
Well I committed to buying it. I am trading a pull behind grill and some cash... SO look for a new build thread by the weekend... cant wait to correct the rigging and make a nice hauler..... will be converting to TBI and looking for a 4l80 or a nv4500 to install GOTTA have the overdrive.... its geared to death
Old 12-01-2010, 03:18 PM   #20
spudz
spudz's Avatar
thanks! yeah he hadnt had it long
Old 12-01-2010, 11:35 PM   #21
87 chevy silverado
whats funny is my buddy wanted to get it right before the guy got it... im going to love my buddys facial expression when i tell him it was up for sale again an already bought again haha
Old 12-01-2010, 11:40 PM   #22
spudz
spudz's Avatar
I will be bringing it home sunday... cant wait!
Old 12-03-2010, 12:06 AM   #23
87 chevy silverado
thats good to hear
Old 12-03-2010, 10:39 AM   #24
old crewcab
take them fl-*ord-mats out and stomp on them!
old crewcab is offline   Reply With Quote
Old 12-03-2010, 11:11 AM   #25
spudz
spudz's Avatar
haha I was waiting for someone to say something about em.. I will put em in my 79 bronco....
