Purchased a Tuned Port Injection L98
I have just bought a complete L98 to put into my 65 and it comes with a harness but I can't remember which brand. I did a search and only found a few post of people using TPI but they have no endings. I have made a list of things I'll need for the install since I'm going from a 6 cyl; radiator, elect. cooling fans, engine mounts and throttle cable.
Is there any other items or insite anyone can add for my swap? I'm also running a T5will I be able to run my original bell housing and flywheel? Last edited by enick72; 12-04-2010 at 03:37 PM. |
Justified!
Re: Purchased a Tuned Port Injection L98
electric speedo sending unit......High GPM fuel pump....return fuel lines...
Make sure the chip is burned for the trans/wheel/gear setup you have.... Electric gauges.....or at least a speedo.... O2 sensor... knock sensor probably some other stuff i can't remember good luck!
Chad 1964 GMC Fleetside Shortbed....350/700R4 tranny ![]() |
The speed sensor is one of the things I had not thought of. My T5 is sensor output (no cable) so I will be adding a electronic speedo anyway. I also had not thought about a fuel return, can this be done with factory tank/sendin unit?
![]() Join Date: Aug 2009
been running a TPI since they were the newest SBC, now its outdated and obsolete in the chevy world but I happen to like mine so it will stay, I installed a TPI in 1994 in my 62 C10, I used the factory harness and rewired a few things and never have run the speed sensor..it has been on the list of things to do but it was never an issue, torque converter locks and unlocks and everything works, the speed sensor they say is necessary but its for the cruise and the mass air burn off function, if you want to run one you need a 10 pulse per mile, I used an 8 ppm one on another project from a very early Jeep cherokee (inline with GM speedo cable sizes on each end and it works fine, I have an inline one from painless I will install one day on the 62, I have a mid 90s Ford Ranger fuel pump and it has worked great, I have used them in about 6cars I converted to EFI and they are a great loe cost alternative, its an inline pump that is actually a bosch unit and the factory Ford mounts work well in hot rod applications, PM me if you ahve any questions
the way I did the return was to tap into the tank sending unit and bend a line all the way along the stock pick up, I used stainless saftey wire and wired it to the fuel pick up line and silver soldered it in, been working for all these years, the first time I did it I ran the line in at the top and did not run the line below the fuel level and it caused a constant gas smell in the cab because of the returning fuel, the 2nd way I described works great and no more fuel smell, I used the stock fuel line for the feed to the pump, I am in the middle of cleaning up the TPI install and will be re routing the fuel inlet on the fuel rail to the rear to make the lines easier to route
Thanks for the info I will more than likely contact you as I get closer on this project. Are you running MAF or MAP? How did you run yor air intake?
I am running MAF just because it will respond more to engine upgrades (cam heads, ect) than the Map (speed density) systems, I have a 92 TPI firebird intake hose to a remote filter from some mid 90s buick you can see part of it in the pics, I have since removed this and will be using a boxed K@N cone, I am going to make the box myself
Good luck with your install. I really like the TPI system. Its outdated like Bugeye said but it looks cool under the hood. Too bad it was OBD 1 though. You can still get plenty of response from the go pedal with it, especially if it is a daily driver.
Betty : '63 Fleetside Longbed 350 w/ 4 speed CPP 3/5 drop with front sway bar. |
I have a semi ported intake(removed the EGR stuff in the air flow) and an air foil in mine and a chip and it has left skid marks in a few pants over the years, its got dual ex but I am going 2 1/2 with x pipe which should help things out, the key is the lower stall 6 cylinder auto trans I have, the T5 should be great too, just make sure you get a world class version 92-94 I believe, not all T5s are world class, the reg t5 will not last long with the weight of a truck
#10 | |
#11 | |
Due to financial constraints, the light at the end of the tunnel will be shut off until further notice |
#12 | |
#13 | |
yes it does take alot of tuning to get it right i just like the ease of switching fuel tables from saved files in less than a minute you can go from cruising economy to performance but for the guys that like to burn there own proms try here a real econimical way to diy your own chips http://www.moates.net/
#14 | |
#15 |
I bought my VSS and some air intake ducting from www.jagsthatrun.com They have a good TPI swap book too.
A great resourse is www.chevythunder.com I had Brian at tpichips.com burn my chip for me. I told him what I was running on the engine and tranny and such and he burned my chip for me.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
#16 |
Do you have any experience running a muncie speed behind a TPI?
#17 |
#18 |
i agree you can pickup an inline speed sensor from howellefi.com and i think summit sells one and use any trans you can think of
