Old 12-04-2010, 05:31 PM   #1
samstheman
front lower coil spring in a 77
I have a new 2'' lowering spring Im not sure if I have it seated correctly in a 1977 the stock one was locked up top a little and I have some energy spring bushings for rear springs should I use these also up top in front.
samstheman is offline   Reply With Quote
Old 12-04-2010, 08:01 PM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: front lower coil spring in a 77
Welcome to the forum samstheman. Is there a reason you don't feel the springs are seated correctly? You should be able to seat them the same way the stock springs fit in.
I'm not sure what your asking here "I have some energy spring bushings for rear springs should I use these also up top in front. "
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 12-04-2010, 08:29 PM   #3
samstheman
The bottom doesnt hit the same stop with the shorter spring and the top I think I have the top in correct just not positive its shaped like a D the spring starts on the flat of the D on top of the hump
