Old 12-04-2010, 11:40 PM   #1
69Beauty
69Beauty's Avatar
Vortec Head Questions
I am wondering is these springs will fit on stock vortec heads? http://www.compperformancegroupstore...ct_Code=981-16
I m wondering becuase i am thinking about putting some vortecs on a 350 or 400 small block in my 69 c-10. I have many threads and articles on the guide bosses and how youhave to cut them for springs for more lift. i also read about some beehive springs that work with no machining. i looked and these have the same inside diameter so i don't know how they wouldn't work but have know idea. the cam i plan on running is the Comp 270H http://www.compcams.com/Company/CC/c...x?csid=78&sb=2
Any help is appreciated. Thank you.
1969 C-10 LWB 388 SBC Vortec Heads 10:1 Lunati 60103 cam Weiand intake Quadrajet Carb 12 Bolt 3:73 posi 700r4 Hedman Headers
1998 Dodge Ram 1500 Reg. Cab Long Box 4X4 5.9L 183k miles
1956 Ford F-100 Longbed with Original 272 and 3OTT
1995 C1500 ECSB 6.5 Diesel 4l80e (Camper puller)
1997 Dodge 3/4 ECLB V10 (MPG machine)
69Beauty is offline   Reply With Quote
Old 12-05-2010, 08:11 AM   #2
jim zag
ENGINE BUILDER
jim zag's Avatar
Re: Vortec Head Questions
You might have to remove the dampner from the inside of the springs because GM made the spring seats to fit springs without a dampner. It's no big deal. You must shorten the valve guide to provide .060 clearence between the top of the valve seal and the bottom of the retainer at max lift. 270 Magnum is the perfect cam for the street. Do not use an AIR GAP style intake because they hesitate and are cold blooded when the weather is cool, I will not install one on a customers engine. If you use aftermarket valve covers check to see if your rocker arms rub on the inside of the covers by the pushrods. I sometimes have to grind the rockers so they will clear. I had a customer put cast aluminum covers on an engine I sold him and it would only run with the covers off!!!!!!!!!! The valve covers were rubbing on the rockers! Expect lots of POWER!
JIM ZAG
jim zag is offline   Reply With Quote
