Old 12-07-2010, 01:30 AM   #1
GMC70c20
l92's on a lq4
I have a lq4 I am putting in my truck it is complete but stock. I want to replace the heads but still run the injection, I looking to make about 600hp. Can I use my factory intake with a set of l92s or would i have to get a lq9 intake or a carbed intake. I'm sure It will bolt up but I want sure on the port alighnment.
1970 c20 converted to c10 sleeper
1979 c20 the wood hauler
1991 honda civic daily driver
spray and pray baby
GMC70c20 is offline   Reply With Quote
Old 12-07-2010, 02:08 AM   #2
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Re: l92's on a lq4
you would need the L92 or LS3 intake (or a carb'd one w/fuel rails) to go with the L92 heads on your LQ4.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 12-07-2010, 07:13 PM   #3
GMC70c20
Re: l92's on a lq4
thats what I was affraid of. Maybe I'lle just deck my stock 317 castings, I know the engine stock is 9.5:1. I woulnt mind gettin it up to 10.5 or 11:1 and I was also orignially looking at the gm "hot cam" (I thought about 9.5:1 and a turbo but that kinda fell through)
maybe a little biger cam and 11:1 would get me to about 500 or 525 hp.
spray and pray baby
Old 12-08-2010, 01:20 AM   #4
68GMCCustom
Re: l92's on a lq4
the 317's aren't bad and will make some power for you....you can always upgrade later....
Kurt -
Old 12-08-2010, 09:58 AM   #5
Shon
Re: l92's on a lq4
L92/LS3 all the retangular ported heads need a big engine and a decent cam shaft to use all that air. Sure the L92s flow alot of air and show decent dyno numbers...we consistantly out ET and MPH L92 headed cars with 243s.....
My issue with the L92s is that you need a 400+ cubed motor and the right cam to make it worth the effort, and when I say effort I am including just what you mentioned here, you going to need a specific intake, 1 set of offset rockers and the big motor.
I would take the 317s and you know they are 243s just with a larger chamber, send them to me to be worked/CNCd by Advanced Induction in NC. The results will be amazing, and you can get a used FAST 90/92 and a TB and be making good power to the tires.
Now if you are stuck on the L92s then FAST does make the 102 for those heads now but you will have to get a 'car' intake, thet truck one is catherdral ported. I also know where a LS3 intake is and dont forget the fuel rails and injectors.
Stock truck injectors are going to run out of steam on a stock 6.0 with with a cam swap and there are not any good Multec IIs out there so you will have to change the connector to either EV1 or EV6 style.
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap
Shon is offline   Reply With Quote
Old 12-08-2010, 02:12 PM   #6
68GMCCustom
Re: l92's on a lq4
its funny to listen to the L92 stories.....too bad your not close enough to run mine Shon!
Kurt -
Old 12-08-2010, 02:26 PM   #7
Shon
Re: l92's on a lq4
yeah, its too bad I am not closer to run a cam'd 6.0 with a stock LQ4.....
Not saying they dont work and make great power but when you are starting out with a complete motor already there is more to the L92 swap than just putting the heads on there, you got to have the rockers and intake and to really use the air flow, you need supporting mods and IMO that includes the right cam and a larger motor.
Old 12-08-2010, 07:53 PM   #8
68GMCCustom
Re: l92's on a lq4
hey you're always saying that the L92/LS3 headed cars/trucks can't hang with a good cathedral port one! Just thought I'd give you a shot at mine when its ready.
Well the way I look at it.....the GM engineers must know what they're doing to bring us these fantastic motors in the 1st place right? And, since the factory is building 6.0L motors with the new genIV L92/LS3 style rectangular port heads (LY6, L76, etc)...they must not think that a 6.0L's bore is too small (or shrouds the valve too much) for the rectangular port genIV heads?
As far as the swap...only the intake rockers are different, but the exhaust have the same rockers as a catherdral port head. And you're right, no..........the big port heads aren't for everyone.
Kurt -
Old 12-08-2010, 09:00 PM   #9
Shon
Re: l92's on a lq4
So you calling me out with a truck that is not even ready
And I might put some of these heads on the next set up...fixin to start another Z28 with at least a 6.0.....and a 200 shot.....
Old 12-08-2010, 10:22 PM   #10
68GMCCustom
Re: l92's on a lq4
uh.....yeah. pretty funny huh?
Kurt -
Old 12-08-2010, 10:30 PM   #11
Shon
Re: l92's on a lq4
Thought it was just an upstate SC thing but looks like the standard call out has a 6mth lead time
Old 12-08-2010, 10:41 PM   #12
68GMCCustom
Re: l92's on a lq4
oh heck.....I can be ready before that!
by the end of the month maybe....hopefully before Christmas!
Kurt -
Old 12-08-2010, 10:43 PM   #13
Shon
Re: l92's on a lq4
That's better turn around than most!! let me know what it runs and the DA!
Old 12-08-2010, 10:53 PM   #14
68GMCCustom
Re: l92's on a lq4
1/4mi tracks are closed....but there are a few 1/8mi tracks that might be open on a nice weekend. I need to take it easy at 1st tho....although my 12 bolt was rebuilt about a year ago w/3.73's and a new Eaton posi, and I just had a heavier driveshaft made...I don't think I trust it to nail it from a stand still on a sticky track and still get me back home.
Once I upgrade to a Dana 60 or 14 bolt...and upgrade the u-joints to 1350's minimum (couldn't do it with this new shaft w/o pulling the R/E apart again)... I should be able to start working on dialing in the 60' times. 13's, then 12's, then 11's...thats the plan.
Kurt -
Old 12-09-2010, 08:44 AM   #15
Shon
Re: l92's on a lq4
LOL, I took my junk out and only thing changed was the U-joints on the trans side and hit it with a 100 shot and went 7.8s in 1/8th mile....i figure with those L92s and cam you have you should run low 8s on motor....
Old 12-09-2010, 11:28 AM   #16
68GMCCustom
Re: l92's on a lq4
....I just need to get it together and running! Who knows.....I may not be able to restrain myself... and beat the crap out of it from the start.
Kurt -
Old 12-09-2010, 11:33 AM   #17
Shon
Re: l92's on a lq4
Find the weak link!
I was able to pull a 1.76 60' on a very rich 150 shot on 28" slicks with 3.73s.
Here's some motivation:
Old 12-09-2010, 11:43 AM   #18
68GMCCustom
Re: l92's on a lq4
mine also has 3.73's... and a 200-4r which has a little better 1-2 ratio to hopefully keep it in the powerband better then the old turbo350. I've been planning on running drag radials instead of slicks...to run steet/bracket?
Kurt -
Old 12-09-2010, 11:51 AM   #19
Shon
Re: l92's on a lq4
My set up went alot quicker on 26" DRs.
8.8 on motor and 7.8 on 100 shot.
Went to 28" slick and went 8.0s on 100 shot and did not pick up any on a rich 150 shot.
I actually might be pulling this motor (6.0) and get a complete 5.3 and put a cam in it to tow the 94Z I just picked up, use the 6.0 out of truck to put in the Z with the ported 243s I got here and some cam...I think with that set up and a 200 shot the car should run pretty well (when compared to locals). And then if I get froggy I would port some L92s from the same place and just do a back to back comparison....not a good comparison b/c the L92s actually need a different profile but something to look into....
Old 12-12-2010, 09:56 AM   #20
pharmd
pharmd's Avatar
Re: l92's on a lq4
Yeah, Shon, def gotta swap to another cam profile more akin to the L92 heads to make that a fair comparision...if this thread were on 'tech their would be a firestorm. Mamo and patrick G would be doggin the L92's saying you need some AFR 215's and a bunch of others would be swinging on the L92's...IDK, I haven't seen a whole lot of impressive ET/MPH with the L92's...AI did their L92's with LG's G6x3 on a stock SB LS3 and made well over 500rwhp, but that's just dyno #'s. I've seen AI 243's on 6.0 stock sB with fAST, 23x's cam, headers make almost 500rwhp thru a stalled auto...so I see both sides...
2007 TBSS 418ci AI CNC 243, Futral cam, ARH headers, RPM VI tranny, Vig 2800, 430awhp/426awtq 12.1 @110
2002 Camaro SS 346ci Heads/Cam/Intake ARH headers M6, Koni, UMI, magnaflow, DMH, Meizere, ATI, 456rwhp/414rwtq
1965 Chevy C-10 Stepside, 355, TH350, 3000 coan stall, 4.10...Going under the knive!
http://www.hubgarage.com/mygarage/profile/28922
pharmd is offline   Reply With Quote
Old 12-10-2010, 04:06 AM   #21
matthew20061
69' Chevy Stepside
matthew20061's Avatar
Re: l92's on a lq4
This coming May mine will be out at the track up here in Alaska, and we'll see what 1/4 mile times it'll do with the new LQ9 6.0L with L92 heads and cammed. I'm also running 3.73 gears with Positrac in a 12 bolt. 4L60E with 3200 converter. Need to get the tune finished before I head out to the track in the spring though!
-Matthew
-69' Chevy Custom/10 Shortbed Stepside 2WD "Copperhead"
- Restored, 6.0L LQ9 Built. L92 Heads and LS3 Intake with Comp Cam 223/231 .610/.617 112 LSA, 4L60E with Shift Kit and Circle-D 3200 Stall Converter ~Build Thread
-1957 Chevy BelAir 2 Door Post Sedan, Full Frame off Restoration done myself - 6.0L with T56 six speed
-1957 Chevy BelAir 2 Door Post Sedan - Nearly rust free AK car, Project in the waiting
-2003' Chevy Silverado SS AWD 6.0L! - Daily Driver
matthew20061 is offline   Reply With Quote
Old 12-10-2010, 06:48 PM   #22
68GMCCustom
Re: l92's on a lq4
our trucks matthew....with both being L92 headed 6.0L's with the same cam and rear gears...but just different induction systems and transmissions. Oh and mine has a lower stall in it.
Kurt -
Old 12-11-2010, 03:00 AM   #23
matthew20061
69' Chevy Stepside
Re: l92's on a lq4
It should be very interesting to see how they do, basically Carb vs. MPFI! With some minor differences in exhaust and stall speed.
-Matthew
Old 12-12-2010, 10:04 AM   #24
Shon
Re: l92's on a lq4
Advanved Induction knows their stuff!!!
That 6.0/243/23x/500 thru stalled auto is probably my buddy Jeff's GTO you speak of...that car was fast. we had a track day where he was there and another GTO was there making about the same dyno #s with L92 but Jeff's car was out MPH'ing him.
Old 12-12-2010, 10:21 AM   #25
pharmd
pharmd's Avatar
Re: l92's on a lq4
Yeah, didn't he tear something up in the drivetrain before he got to maximize the combo? He had the Ed Curtis flowtech cam right?
