12-07-2010, 05:00 AM | #1 |
Gettin It One Pice At A Time
Temperature sender
Hello,
So I just finished breaking in a new motor. And the heads are from a 84 van and my truck is a 79. The temp sender hole is bigger. So we got the BWD WT359. And I think it is not accurate. I think its reading higher then it is. Is this the right sender? The one from my old motor was a 3/8 inch sender, the new one is the 1/2". If this is the right one, then I guess I'll just keep that in mind and live with it. Thanks! update: I am not 100% sure that is the right sender I got. I will look tomorrow when I get back to the shop.
RIP ELJAY Work In Progress 1979 GMC C1500 Trailering Special. Getting the truck done, one piece at a time. “You can tell a lot about a fellow’s character by his way of eating jellybeans.”Ronald Reagan “I don’t know the key to success but I know the key to failure is trying to please everybody.” Bill Cosby Last edited by 79gmcc15; 12-07-2010 at 05:11 AM. |
12-07-2010, 11:02 AM | #2 |
Insert Witty Text Here
Re: Temperature sender
I had the same problem after my engine swap. The new engine had the larger hole, so I went with a sender from a 70s truck. It indicated very high, and scared the youknowwhat out of me during break-in. I used an adapter to put the old sender in, and it read normal. Get a new replacement sender that is like the old one (or re-use the old one) and you should be fine.
Slonaker |
12-07-2010, 05:58 PM | #3 |
Use the sender that is correct to your truck with a 1/2 to 3/8 bushing.
12-07-2010, 08:56 PM | #4 |
Sorry guys I goofed. Its the other way around. Old is half inch and new is 3/8". So I think if I bush that the sender will be to far our. Or??
RIP ELJAY Work In Progress 1979 GMC C1500 Trailering Special. Getting the truck done, one piece at a time. “You can tell a lot about a fellow’s character by his way of eating jellybeans.”Ronald Reagan “I don’t know the key to success but I know the key to failure is trying to please everybody.” Bill Cosby |
12-07-2010, 10:15 PM | #5 |
I had a similar situation with my '73 truck when I put 305HO heads from an '80s Monte SS onto my stock 307 engine. The Monte SS heads had a 3/8 thread and my truck had something larger. I spent a half hour looking through a Napa Echlin catalog until I found a temperature sender with the correct 3/8 thread size and an ohm range that matched the stock sender. FYI, your stock sender is a Napa Echlin TS6640 and has an ohm range of 138 - 156 @ 220°. My truck uses a different sender otherwise I'd dig up the P/N of the sender I used.
Hope this helps, Ed |
12-08-2010, 01:19 AM | #6 |
Awesome! You rock! That gives me a starting point. Thank you.
12-08-2010, 06:20 PM | #7 |
Here's a link to the NAPA Echlin website
Click on the 'catalog' link at the top and select the electrical components PDF. The temperature senders are toward the back of the catalog. Easiest to use the table of contents. |
06-28-2011, 02:02 PM | #8 |
"the other guy"
did anyone ever find the correct sender for the 3/8 hole?
God Said,"Building A 10 Second Import Is Like Coming Out Of The Closet, In The End Ur Still....."EXPLETIVE" |
06-28-2011, 03:06 PM | #9 |
Try calling Napa and telling them what you're looking for.
1955 Chevy 3600 http://67-72chevytrucks.com/vboard/s...61#post8589061 |
