Old 12-07-2010, 11:29 PM   #1
67Dad
Bolt Pattern for Bell Housing...350 vs. 250?
Our straight six 250 has a cracked cylinder.
Possible replacement located is a 1993 4 bolt 350 SBC.
Does anyone know if the bell housing from engine to transmission would match with the old 250 or if adapters are available (tranny is Muncie SM420 4speed).
Length of drive shaft could be an issue, too, I suppose.
Thanks.
Mark
Mark
57 Austin Healey 3000 (sold many moons ago, unfortunately)
67 C10 (in progress, son's) w/ 1993 350 SBC, '96 Vortec heads (custom polished ports), EPS Performer intake, Holley carb, cam, MSD ignition
93 C4 Corvette (mostly done, son's)
67Dad is offline   Reply With Quote
Old 12-07-2010, 11:30 PM   #2
jablack
Classic Chevy Recycler
jablack's Avatar
Re: Bolt Pattern for Bell Housing...350 vs. 250?
Same pattern, will bolt right up.
2004 Chevrolet Trailblazer EXT
1970 Chevrolet C50
1979 Chevrolet C30
Need another 67 or 68 soon...
jablack is offline   Reply With Quote
Old 12-07-2010, 11:50 PM   #3
67Dad
Terrific. Many thanks for the quick reply! Mark
Mark
Old 12-08-2010, 02:40 AM   #4
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
Drive shaft alterations aren't necessary, just drop the 350 in using your I6 towers and get a upper rad hose and fan shroud from a 4wd truck (they sat in the same location as the I6 too). It will sit back about 3" or 4" farther than the 2wd v8 mounting position, but it works just fine, that is how mine is set up. Anymore questions hit me up.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 12-08-2010, 08:15 PM   #5
57larry
use the V8 mounts, the 6 cyl mounts has the HEI dist right next to the firewall and the fan too far from the radiator. Do it right, the factory way
57larry is offline   Reply With Quote
Old 12-11-2010, 05:08 AM   #6
raycow
If you use the front set of holes you will have to deal with the clutch linkage as well as the driveshaft. Use the 6 cyl holes and save yourself a bunch of work.
Ray
Live more responsibly. Eat lower on the food chain. Eat vegetarians.
raycow is offline   Reply With Quote
Old 12-11-2010, 10:00 PM   #7
RCbowtie69
RCbowtie69's Avatar
I Love Chevy's, BB or SB or 6 cyl. the trans will fit, same bolt pattern,my truck was 6 cyl. now a V-8 cool,still setting were 6 was, from PO, keep on truckin'
RCbowtie69 is offline   Reply With Quote
Old 12-12-2010, 01:58 AM   #8
brad_man_72
the boat guy
brad_man_72's Avatar
you could even bolt up an ls based engine with a crank spacer. Put the 8 on the 6 stands it never hurts these old trucks to move the engine back a few inches. Makes for a better weight bias, that means it will turn better.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 12-12-2010, 03:10 AM   #9
ATrain707
im in the same position, i have a 250 in my 68 c10 1/2 ton long bed with a 4speed. whats the easy way of doing that will work?if i didnt use the 250 mouting holes i would have to drill new ones? and if i use the 6 cycl holes everything will bolt up ok? drive shaft, tranny, clutch? the 350 i bought can with the fly wheel and clutch will these work/bolt with my stock bell housing and with with my 4speed tranny? oh and will the stock straight 6 motor mounts in the trucks work? or should i buy v8 mounts, sorry for all the question and thnx for the help
ATrain707 is offline   Reply With Quote
