12-08-2010, 05:33 PM | #1 |
carb help! Please
i have a 67 with a 250 i6 and just had the carb rebuilt by a friend but it is squirting gas out of this on top. can anybody help me?[IMG][/IMG]
1967 chevy stepside, 292 I6, 4 on the floor, 4.11 rear-end http://www.youtube.com/user/thankins93?feature=mhum MY 67! http://67-72chevytrucks.com/vboard/s...d.php?t=446964 |
12-08-2010, 06:25 PM | #2 |
Re: carb help! Please
I believe that is an air relief so your floats may be set to high
69 Chevy 4x4 383 Power |
12-08-2010, 06:37 PM | #3 |
YOur float is set too high or stuck. Try tapping it with a soft mallet or back side of a screwdriver. If that doesn't stop it, you will need to reset the float.
12-08-2010, 07:14 PM | #4 |
would i have to take the carb back off or could i do it while it is still on? and tap it where? sorry working on this truck is new to me. thank you for the help though, this place is so helpful
12-08-2010, 07:21 PM | #5 |
SSN 706
On top of the bowl. Take the carb off, open the bowl, float operates a needle valve thing. Take it apart and make sure theres not a small piece of metal or somthing blocking the seat. Don't know how to set the float.
Daverods 64 C10 Daily driver 292 3 speed "Driver" Daverods 66 Build C10 Bags 350/350(On Hold) Daverods 52 Build 3100 S10 chassis,Bags, 350/700r4 "Click it" Last edited by daverod; 12-08-2010 at 07:21 PM. |
12-08-2010, 07:20 PM | #6 |
If it has a rubber fuel line going into the carb ,you can clamp it off with vice grips then start the truck and run it out of gas. then tap the bowl ,this works a little better to un stick a stubborn float.
69 gmc 4x4 lwb 327 4sd not running |
12-08-2010, 07:22 PM | #7 |
SSN 706
I'll have to try that sometime. I've never had any luck with the tapping thing.
12-08-2010, 07:48 PM | #8 |
thank you so much for the help, i will try that and tell yall how it goes!
12-08-2010, 10:29 PM | #9 |
Copy and paste this into your browser's address bar: http://www.youtube.com/watch?feature...&v=Kj3igH-i7SU
It will show you how to set the float level.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Sliding Rear Window Power Windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
12-08-2010, 10:33 PM | #10 |
I guess you can just click that link, that would be easier, lol.
12-08-2010, 11:19 PM | #11 |
that video was perfect!!!!!!, im goin to try hitting thing first then take it apart if needed, thank you again, all of you!
