Old 12-09-2010, 09:56 AM   #1
harrydunn
harrydunn's Avatar
Transmission Code / SPID
Morning Guys--
Will the transmission code on the SPID tell me whether I've got a TH350 or TH400? I need to take a photo and post that up I suppose.
Also, I've not been around old transmissions since the days of my '68 Cutlass (2-speed Jetaway) and '74 Camaro (3-spd manual) many moons ago. Would you advise to at least change the fluid/filter or should I leave things alone? I've got some engine oil records but nothing on when the transmission may have been serviced. Shifts very smoothly.
Thanks,
Mark
1972 GMC 2500 Custom, 96K miles, Purchased New By My Grandparents
2016 Toyota Tundra TRD Off-Road SR5
1993/2003/2005 Toyota Land Cruisers
2004 Corvette Z06 / 2000 Covette Coupe
2006 Ducati Multistrada
2014 BMW X3 XDrive35i M Sport
harrydunn is offline   Reply With Quote
Old 12-09-2010, 10:22 AM   #2
slategrove
slategrove's Avatar
Re: Transmission Code / SPID
Here's what you need to identify your tranny...I had to figure out what I had, too.
http://www.maliburacing.com/auto_tranny_id.htm
slategrove is offline   Reply With Quote
Old 12-09-2010, 10:26 AM   #3
No,both will have the M49 code.Weird,but how it was done.Makes no sense.It's like using the same option code for a 350 and a 400.
It wouldn't hurt to change out the fluid and filter,but probably fine as is.Is the color still nice and red?Heat will make it dark and could be a sign the trans has been slipping
Old 12-09-2010, 10:31 PM   #4
harrydunn
harrydunn's Avatar
It's a 350. Thanks for that link.
Old 12-10-2010, 12:13 PM   #5
harrydunn
harrydunn's Avatar
Should have asked this in my initial post. Where can I find the rear-end ratio?
Thanks,
Mark
Old 12-10-2010, 06:26 PM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Some trucks got the car option number (M38) for the TH350, but generally they were all M49 in trucks.
The rear gear, if not listed on the SPID would be the standard ratio for the series/eng/trans.
Assuming we are talking about the 72 GMC in your signiture, we now know it has a TH350... what motor does it have?
Old 12-10-2010, 06:54 PM   #7
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Had a pair of '69's. One had a TH350, and it also had M38 on the SPID. Mine has a TH400 and says M49 on the SPID.
Member Nr. 2770
Old 12-10-2010, 07:39 PM   #8
sameyrasmea72
sameyrasmea72's Avatar
Most spid use M49 for both,but the firewall will use M38 for the 350 and M49 for 400
72 Cheyenne Super
80 Silverado Blazer 2wd
sameyrasmea72 is offline   Reply With Quote
Old 12-10-2010, 08:14 PM   #9
DANTIP
DANTIP's Avatar
Nice catch Jason! I hadn't noticed that.
DANTIP is offline   Reply With Quote
Old 12-11-2010, 12:35 AM   #10
harrydunn
harrydunn's Avatar
Engine is a 350.
Old 12-11-2010, 05:24 PM   #11
harrydunn
harrydunn's Avatar
Metal tab on the bottom left of the diff has a 4.10 stamped on it. I'm assuming this is my ratio? It does scream on the highway at 60 mph so I would not be surprised.
Old 12-11-2010, 07:50 PM   #12
Longhorn Man
you got it, a 350/auto in a 3/4 ton would get a 4.10 ratio standard.
It's MUCH better than the 4.57
