12-11-2010, 08:11 PM | #1 |
switching gas tanks?
My 87 has dual tanks. When I bought it the switch was on the right tank. The previous owner said that the tanks used to alternate by the switch. However the truck sat for about three years. I have had it almost one year and every time I switch the tanks the truck dies. What would you guys check in the order of most likely to quit working. Solenoid under the truck or switch in the cab? Any other suggestions? Thanks.
JESUS IS LORD 87 crew cab V30 454/400 |
12-11-2010, 08:12 PM | #2 |
Re: switching gas tanks?
The truck only runs when it is on the right tank. Not sure if I made that clear. Thanks again.
12-11-2010, 09:05 PM | #3 |
Addicted to Rust
TBI or Carb? If tbi bad pump possibly. Jay
Current trucks: (48 GMC100 320 inliner) Gone (48 Suburban in pieces) Sold 87 GMC CCSB 5.3 4l60E Daily Driver ECTA National record holder XO/PP We never really grow up, we just learn how to act in public. |
12-11-2010, 11:34 PM | #4 |
tbi. I would prefer to check somewhere other than inside the tank first though.
12-12-2010, 12:01 AM | #5 |
The switch in dash would be the quickest thing to eliminate but seems like it wouldn't be the switch. If that was bad i would think it would just be stuck on one tank. maybe bad pump or clogged line??
12-11-2010, 11:58 PM | #6 |
Home Built '87
When mine did that I bought a replacement switch and worked my way back from there....it was in the tank for me though.
Did you try banging on the bad gas tank with a rubber mallet to get the pump working?
Gordon 1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424 1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833 Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969 |
12-12-2010, 04:07 PM | #7 |
The light came on. lol. If the switch wasn't working it wouldn't die. The gas gauge does not move when I switch tanks either though, and I just put 25 in gas in it, so I know it has gas. Should the gauge switch even if the pump is not working?
12-13-2010, 01:39 AM | #8 |
With the motor off, move the switch to the bad tank. Put your ear near the tank and have somebody turn the key on. You should be able to hear the pump buzzing/priming. If you hear the buzzing then its either the switch in the cab or the cross over under the cab. The cab switch is only 18-20 bucks. The cross over under the cab is harder to get to and more expensive.
1995 GMC 4x4 1/2 ton 1999 Jeep Wrangler w/ 33's 68 camaro 350/350 1987 Chevy 3/4 ton 4x4 Suzuki DRZ 400s Dual Sport 1971 chevy long bed 2x4 194? Dodge 2.5 ton 1980 Chevy Cheyenne 4x4 1/2 ton I6/sm455 1989 Chevy V30 crewcab dually 454/TH400 |
12-13-2010, 02:23 AM | #9 |
what if the fuel pump is on the motor? My 82 only works on the left tank, I havent dared try to switch it yet because I'm afraid it will hang up or something and I wont have anything working. So actually I dont even know for certain it is stuck, just going on what the p.o. told me. But he also told me it was stuck on the right tank. Put gas in it tonight for the first time, put 5 gallons in the right tank and the gauge didn't move, so I filled the left one and it went up. Be nice to have them both working.
My 81 used to work and I loved it, but one night when it was really cold it failed to switch over, although the gauge said it did. Flipped the switch, gauge went up to full on the full tank, but I kept running off the low one until it ran out. Tried to swap the fuel lines at the crossover, but I didn't have any pliers and just couldnt do it with my bare fingers. Long night.
1982 Chevy K30 CCLB fleetside. Formerly a cab and chassis, now a fleetside dually with the rear wheels tucked underneath. 454/th400/np205/C14/D60, 6/4 inch LIFT, not drop. |
