Old 12-12-2010, 04:37 PM   #1
m6z
m6z's Avatar
dust shields with belltech 3" 73+ drop spindles?
Anyone running the 3" belltech drop spindles with the dust shields? What year dust shields are you using? Any modifications to the shield? What's the best place to order dust shields from?
My chassis came with the belltech spindles but no dust shields and I don't have any dust shields to check fitment.
Thanks in advance,
Doug
Looking for a 67-72 short bed driver.....
m6z is offline   Reply With Quote
Old 12-12-2010, 04:46 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: dust shields with belltech 3" 73+ drop spindles?
Any 73-87 dust shield will work.
Try to buy used ones,... new ones are pricey,
ECE sells them new.
I think they are available from your local GM dealer also.
Keith
Convert to disc brakes.
Old 12-12-2010, 05:11 PM   #3
SCOTI
SCOTI's Avatar
Yep, 73-87's.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 12-12-2010, 06:30 PM   #4
m6z
m6z's Avatar
Ok. Thanks. Are they a coated steel or aluminum? If aluminum I should be able to clean up a used one to look like new. If coated. It might be easier to just buy new... Looks like they're about $40 each from ECE.
Doug
Old 12-12-2010, 06:38 PM   #5
lolife99
lolife99's Avatar
They are steel.
Probably zinc plated.
I would paint a used set.
Keith
Old 12-12-2010, 06:50 PM   #6
BossHogg69
motor exploder
BossHogg69's Avatar
I used CPP dust shields #CPDS-10, on my Western Chassis dropped spindles. They were $49 for the pair, zinc plated steel and bolted right up. They even came with the bolts.
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
