12-13-2010, 12:01 PM | #1 |
carb/fuel question
I have a '67 3/4 ton 4WD P/U CSTwith a 327 250hp, w/ a "squarejet" carb...I moved from high country in Colorado to Virginia...had to adjust the air/fuel mixture...seemed fine then started experiencing some hesitation and sputters out of the blue...
fuel pump was replaced last spring , and fuel filter is OK...rebuilt carb to some satisfaction, but sputters are still there sometimes as is cutoff...is it possible a rebuilt fuel pump would act this way before total failure??(12k miles) timing and all other issues seem OK...this is an original truck/engine combo w/ only 70K miles on it...so any thought would be appreciated...ted Last edited by silvertip67; 12-13-2010 at 12:15 PM. |
12-13-2010, 12:10 PM | #2 |
Re: carb/fuel question
if you have the original poits have you cleaned and set them on a regular basis as is required
12-13-2010, 12:32 PM | #3 |
thanks...the points are new...maybe they are not set properly...will check, then get back...thanks again...t
12-17-2010, 09:56 PM | #4 |
thanks for the advice...after some deeper checking I found a plug wire rubbing on the exhaust manifold...it appears its caused the distributor cap to develope an arc mark...
it was the points afterall...thought I did a better job on those wires...thanks again...t |
