12-13-2010, 03:53 PM | #1 |
72 c10 Rear Dif gear options
I have a 72 C10 12bolt rearend under my 65, I had it rebuilt a year or so ago and stuck with the 3.08 gears, what can i put in there without changing the housing? 3.42\3.73?
Thanks guys.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
12-13-2010, 04:08 PM | #2 |
GobbleStalker Calls
Re: 72 c10 Rear Dif gear options
I think you can do both. Check with Randy's Ring & Pinion.
72 Chev Longbox Highlander edition. Med Olive/White/ Med Olive 350 4bbl with 350Turbo trans. Truck currently under construction. Project Cappaccino. Stay Tuned! 1967 Chevy C10, 327, 4.11 posi 3 spd. The Driver Truck! SOLD! 09 GMC Sierra SLT All Terrain pkg. 2014 Jeep Wrangler Sahara unlimited. ( The wifes ride ) |
12-13-2010, 04:11 PM | #3 |
It is my understanding that 3.xx gears will all go into the same housing...
Allengator Outta the Blue (my band - available for hire in the DFW area!) 1980 Chevy SWB Pickup (build thread) 1951 Chevy Sedan Delivery 2004 Chevy Tahoe Z71 2011 Harley Davidson Street Glide 2018 Silverado Z71 Crew Cab |
12-13-2010, 04:18 PM | #4 |
You can put any 12 bolt gears in the housing. However, if you want to keep your present differential case you can use OE type gears only up to 3.42. For anything numerically higher you have to use a special aftermarket gear set with a "thick" ring gear or a ring gear spacer, which some people advise against. I am neutral on the spacer.
Ray
Live more responsibly. Eat lower on the food chain. Eat vegetarians. |
